  #21
Old 09-15-2018, 03:07 PM
Rockman413 Rockman413 is offline
Default Re: What are these yellow indicators at the meter?
Hi there,
This is the screenshot, as you can see Track 1 is sending audio to bus 1 and track 2 is receiving from bus 1.
Thanks to the answers in this posts, that :
I think the first track's yellow clip means it's clipped inside the DAW, and the 2nd track's red clip means the output is actually clipped.
Makes perfect sense right? However, look at my next post
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
  #22
Old 09-15-2018, 03:14 PM
Following the previous post:
In this screenshot: track 2 is also getting the audio via a bus from track1.
Track 1 is internally peaking/clipping, track 2 is suppose to peak in red like my last post, but it peak/clipping in yellow, which got me confused. What does this mean?
  #23
Old 09-15-2018, 04:08 PM
amagras amagras is offline
Were you using a Master Track when you took the 2nd screenshot? That probably means the 2nd track is not going directly to the output
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
LED Clip Indicators - Different in PT8 than PT7.1? bugnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-12-2011 04:05 AM
Volume meter spiking to yellow, not recording anything Drecan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-25-2010 05:26 AM
Track meter instantly goes to yellow Thedy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-22-2006 12:05 PM
Track meter goes instantly to yellow Thedy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-21-2006 10:50 AM
clip indicators Guruman Tips & Tricks 2 04-16-2002 12:56 AM
