What is the most user friendly PT interface?
I know this is a subjective question, but I have been using PT 12 on a Mac for about two years now, and run a RME Fireface 802, along with a FerroFish A16 unit. The RME unit has always been a steep learning curve to use, although there are many advantages to it.
I was just wondering what would be the most user-friendly option if I would change over to a different interface, concerning routing, I/O's, etc? There's no reason for me to go HD at this time. Any advice would help.
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM Slate Raven MTi2 / Artist Control |
Re: What is the most user friendly PT interface?
Do you have a thunderbolt port? If yes, then look at the new Presonus Quantom. One thing that many(most?) 3rd party interfaces use is their own monitoring/routing software, which can add to complexity(as a way of getting around latency). The Quantom is supposed to have extremely low latency so they don't need this extra layer. I run HD/Native here(with HD IO and 192) and once IO configuration is done, its pretty darn easy. Using Avid-branded hardware is often the most friendly(anything that sidesteps the extra software)
A lot depends on how much I/O you need. A big step up in price but also sound is the Apogee Ensemble. Got some nice features if you track guitar & reamping. Under $3k |
I'd get an Apollo. Start with a Twin and then add as needed. Their stuff aggregates like no one else's. You get DSP and awesome plugs to track and mix with. Done.
I have two 8Ps that I lightpipe into my HD rig and it's like having a 16 channel SSL, Neve, API, etc for under $6k. I also have a Twin I use for mobile stuff. |
RME is tech-y in a German way. Apollos are tech-y in an American way. I contend that if the RME felt "unfriendly", then an Apollo might not. Plus it's the smart choice.
Some of this is going to come down to does the op need the dsp in the Apollo ecosystem? edit for additional: We don't know what exact Mac the op has but if I had to guess and if his sig file is correct it's an older cheesegrater and those don't have Thunderbolt ports. |
It’s an onscreen fader. You reference volume via the faders....output volume on the HP’s via the mix screen’s fader level. Just like you would an actual console. Nothing is easier, and if they tell you it is they are trying to sell you something All 3rd party low latency interfaces require you to use an extra layer of software to achieve LL. These all require extra work and knowledge to make them work properly (ie routing/monitoring) - they may have some benefits but “ease of use” is not one of them. For ease of use Avid’s mixer wins....
In all cases, I recommend watching some tutorial videos. The Apollo is a great piece, BUT it REQUIRES you to work in its own window as a "go between" with PT. That's why Avid hardware or Quantom(or anything that DOESN'T have an extra layer of software) is more "user friendly"(a subjective opinion).
As for "how do you reference your volume and routing levels if you don't have the screen like the RME does?" I'm not clear on the question. I have all the metering I need right on the screen(MIX or EDIT window).
Pro Tools = Very Non-user friendly Interface | Glide | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 11-27-2005 10:57 PM |
Seek friendly-helpful PT user to corraspond with. | DVDave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-12-2004 02:07 AM |
Cross platform user with question for veterans | jpd52 | Pro Tools TDM Systems (Win) | 1 | 01-28-2004 11:33 AM |
Most reliable and user friendly Mac+PT setup? | kbahjat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-09-2003 09:47 AM |
Dsp friendly eq? | Allbaldo | Pro Tools TDM Systems (Mac) | 2 | 12-23-2002 08:29 AM |
