Tempo problem
Problem: All is fine with tempo until after shutting down my PC. When starting back up, the tempo plays faster than originally composed. The Bars/Beats that originally were at 98 bars when the song finised in 4 minutes, 20 seconds (4:20), now shows 131 bars at 4:20. I manually reset the tempo to the original setting (90). When I do this, the Bars/Beats go back to the correct 98 bars at 4:20, but the playback continues playing at the faster tempo. I believe the faster tempo is the default 120 tempo setting. I've tried everything I can think of to get the playback back to the intended tempo
(90) but nothing seems to work. Any ideas??? |
Tempo problem
I am lost, but more understanding may help...
You using sample or ticks timebase? What interface? What sample rate is the session at? What sample rate is the interface at? (does it have a front panel display or control panel to check?) Make sure Windows audio or other apps are not using the same interface. Sent from my iPhone using Tapatalk |
Re: Tempo problem
Indeed^^^ I suspect a sample rate/clock issue. If you have a 44.1K session and play it with a 48K clock, it will play faster and higher in pitch.
tempo problem | hornedrum | Pro Tools M-Powered (Mac) | 0 | 03-23-2009 07:18 AM |
TEMPO PROBLEM IN 7.0 | Musicb4hw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-27-2006 07:44 AM |
tempo problem | shade13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-26-2006 04:35 PM |
Tap tempo problem | magicbudster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-14-2005 02:26 AM |
Tempo map problem - please help | 1m1 | Pro Tools TDM Systems (Mac) | 2 | 11-19-2004 03:36 PM |
