iTunes audio output through Digi hardware?
I am trying to get iTunes to play through my Digi hardware and it isn't happening. Toast plays through the Digi stuff, so I know that the System Preferences are setup proper and functioning. Is this simply not possible with iTunes? If so, anyone know why not?
Re: iTunes audio output through Digi hardware?
Restart your CPU and make sure you open up ITunes B4 a PT session ...thats how it works for me....Let me know if that works for u!
The Bronx Bomber |
I have trouble if the sample rate of the LAST Protools session was anything other than 44.1/48.
I have to open a 44.1 session then close protools for itunes to play..... good luck
www.roguewaverecording.com Dual 2.7Ghz PPC G5/2.5 Ram/OSX.4.9 PT 7.3.1 cs3/HD Core/Accel/Process |
I've found I can't have protools open with any other programmes requiring the hardware.
It doesn't like sharing it's toys! Quit protools and you should be okay. cheers, John. |
Can't use 002R with iTunes as an audio output | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-17-2010 11:23 PM |
itunes thru digi hardware | blastula | Pro Tools TDM Systems (Mac) | 13 | 09-25-2007 01:29 PM |
using mBox as audio output for iTunes | aandina | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2006 10:02 AM |
setting up itunes to play through digi hardware | Alex Rodriguez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-11-2005 10:50 AM |
Classic Mode Audio Output Thru Digi Hardware? | flymax | Pro Tools TDM Systems (Mac) | 3 | 08-04-2004 04:02 PM |
