No Midi Data on Midi and Instrument Tracks
Hey Guys,
I am running Pro Tools 10, Focusrite Scarlette 2i4 interface, Yamaha Motif XF8,X8 Studio monitors,Mac Book Pro 10.8.5 I am trying to record Instrument tracks on Pro Tools 10……The Outputs show both Audio and Midi levels are getting info and the audio coming out of the monitors is perfect……but when I record……..no midi notes show up and thus no "Music notes" show up in Score Editor…….and No Midi Level when trying to Record on Midi Tracks.. I have uninstalled both Pro Tools 10 and Yamaha Version 1.5.0 Jeff |
Re: No Midi Data on Midi and Instrument Tracks
Have you made the necessary connections in OSX audio/MIDI setup? This is basic but try this: Create a new MIDI track and see if there's any activity on the track meter when you play your Motif. If there is then at least the Motif and computer are communicating correctly. |
I use both 5 pin for Midi and USB for Audio……THe Focusrite Scarlette 2i4 is for both Audio and Midi……and yes I have tried both MIDI tracks and Instrument tracks and also did have the other setting you mentioned…Thanks!….Still working on it!
Are you trying to record the audio output of the Motif in PT? If you are using the Scarlett for both audio & MIDI there's no need to use the USB of the Motif for audio - use the regular analog outputs of the Motif into the Scarlett for audio.
Issue with Midi in on Instrument tracks and midi tracks | JMR Studio | macOS | 0 | 08-03-2014 08:25 AM |
Routing MIDI data from one instrument to another | DAWgEAR | Virtual Instruments | 4 | 01-06-2014 11:43 AM |
midi track record turns off all other midi/instrument tracks delay comp | holyspicoli | Virtual Instruments | 4 | 07-18-2013 06:14 AM |
Multiple MIDI Tracks controlling one Instrument Track's MIDI | daniel.yengle | Tips & Tricks | 3 | 05-04-2011 03:27 AM |
Moving Midi Data Between Instrument Tracks | overnight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-14-2009 10:10 PM |
