Old 03-28-2017, 03:57 PM
pitbulltodd pitbulltodd is offline
Default Recording with real head-no cab?
can you connect a tube head and use the 11 racks effects, cabs and audio interface into a daw for silent recording?
Old 03-28-2017, 07:55 PM
Pingafuego Pingafuego is offline
Default Re: Recording with real head-no cab?
You need a load box between amp head and Eleven rack. There's a nice article at Premier Guitar website
You must always have a load of some sort connected to your speaker-out jack, or you can severely damage the amp. This is where load boxes come in: They safely load your guitar amp and allow you to use it in numerous ways with no speakers. Examples of load boxes include the Suhr Reactive Load, Koch Dummybox Studio/PA, and the Two Notes Torpedo Live."
https://www.premierguitar.com/articl...ors-and-reamps
Old 03-28-2017, 09:29 PM
zedhed's Avatar
zedhed zedhed is offline
Some heads have a 'direct out' in which case you can just plug that into the 11R and use the Amp/Cab as normal with a feed to 11R/DAW.
Or you could use the Amp head FX loop send to 11R FX loop return. Bare in mind FX loops on most heads are post Pre-Amp/Pre Power Amp which may have an effect on whether or not to use simulated amps in 11R.
You would need to position the FX loop block in the 11R at beginning of chain to send 11R FX to DAW.
As stated above though, for 'silent recording' you need a dummy load on the amp if you disconnect cab. Do not plug this output (to Cab) to the 11R under any circumstances.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 03-28-2017, 10:00 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yeah I also have a direct out on my Marshall but keep in mind that it doesn't sound the same, like at all.
Just use the 11rack - it's good enough by itself
Daniel
Head to head shoot out: Matchless D/C-30 vs. eleven rack MS-30 Chad Pippin Eleven Rack 11 07-26-2012 07:21 AM
Amp Head Recording Static Noise Simba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-31-2010 03:51 PM
Amp Head Guitar Recording Help Simba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-13-2010 07:11 AM
Recording in real studio, mixing at home w/ Pro Tools, mastering at real studio scummyjob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-17-2010 03:02 AM
PT Not recording with a 8 hour project head?? A PT User Pro Tools TDM Systems (Mac) 2 10-09-2001 04:06 PM
