Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 01-16-2015, 04:30 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Maag EQ4 TDM version distortion/ crackling
Just an update in case anyone else is experiencing this. I found i was getting a very low subsonic output when the audio was stopped on version 1.4 TDM
I have reverted right back to version 1.3 for TDM and using 1.5 for AAX 32 This is on Pro tools 10 HD and so far so good.
I will try and investigate this further and contact PA to see what they say but as its working ok now I'm happy...
This shows the problem I'm having with V 1.4 TDM...
NO AUDIO on this vid as there is no audio sound!! but it shows the subsonic level I'm getting on the meters, toggling bypass you can see it stops..
Private video only works with this link...
http://youtu.be/5HY-gMcUgJM
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-19-2015, 10:41 PM
M2E M2E is offline
Originally Posted by crizdee View Post
Chris
I had the same issue.
I still use 1.4.
I told them (Plugin Alliance) about it but, never got fixed.
Hopefully more people will relay their issue as well and it gets fixed.
Marc
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies)
YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc
Old 01-20-2015, 04:32 PM
innesireinar innesireinar is offline
Same here, I've noticed this on a sampled rhodes (Scarbee). But given that TDM is dying I doubt that it will be fixed. Just curious how the aaxdsp works.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 08-19-2020, 12:04 AM
groovebrother groovebrother is offline
Hi, i am actually looking for the EQ4 (tdm version) but i cannot find any info on which version it was at the time ?
1,4 ? 1,3 ?
I also have a EQ2 licence but plugin alliance keeps telling me that only the latest version is available for download. Is there any one tat has a rtas version of this EQ ?
EDIT : found it !!
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
mbox2 periodic crackling and distortion grafic macOS 11 02-14-2015 10:38 AM
Distortion/crackling clips SteveFireland Pro Tools M-Powered (Win) 1 04-13-2010 04:56 PM
Elastic Audio - Crackling, Popping, and Distortion lclebsch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-08-2009 05:24 PM
Smack! causing HORRIBLE distortion crackling problems ProToolsIgniter Pro Tools TDM Systems (Mac) 2 05-23-2007 08:40 PM
bizarre crackling distortion InjuredEar Pro Tools TDM Systems (Mac) 5 03-22-2006 07:40 PM
