Old 07-13-2008, 12:51 PM
Kirby B. Kirby B. is offline
Default 6088 and 6085 errors FIXED
Hi. I have been trying to solve my problem of about two weeks for a few days now and have looked on the DUC at the general troubleshooting sticky and searched for 6088 and 9093 errors and haven't come up with something that works so here I am with the post. My computer seems to run fine in everything and not related to ProTools and has run PT well from the December build until recently.
Of note:
- LE 7.4cs4 002R
- It passed a DPC latency check and I swapped RAM so that's not it
- I did a reinstall with no change. Also put all plug-ins in the "unused" folder with no change
- CPU usage is about 10% in a session - 400,000 kb to 600,000 I think this must be in a normal range.
- the errors come with no plug-ins or many
- all the preferences are default except that I have limited recording time to 60 minutes
- I have done all the general troubleshooting suggestions with the exception of the internal sound card which is enabled
- when I put the mouse cursor over "File", "Edit" etc it doesn't fill in the options right away. That is to say that if I select "File", for example, there is a blank spot below it for a moment before the options fill-in.
- I am not sure that this a PT problem. It could be that I only notice it in PT because of it's resource demand. How can I test the computer?
I have a Sandra report below and hope that someone can figure something out or at least give me some ideas to try.
Thanks very much
SiSoftware Sandra
System
Host Name : LA-FORGE
User : Kirby
Workgroup : WORKGROUP
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Speed : 2.40GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
System
System : System manufacturer P5K-E
Mainboard : ASUSTeK Computer INC. P5K-E
Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : American Megatrends Inc. 0603
Total Memory : 3.25GB DDR2
Chipset
Model : ASUS P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 267MHz (1.07GHz)
Total Memory : 11.13GB DDR2
Memory Bus Speed : 2x 401MHz (802MHz)
Video System
Adapter : NVIDIA GeForce 7300 GT (256MB, PCIe 1.00 x16)
Physical Storage Devices
WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (C:) (D:)
WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (E:) (F:) (G:)
LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (H:)
LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (I:)
Logical Storage Devices
WinXP (C:) : 87GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
Samples (D:) : 200GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
DOCUMENTS (E:) : 7GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
MUSIC (F:) : 227GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
ARCHIVES (G:) : 65GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
CD-ROM/DVD (H:) : N/A @ LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache)
CD-ROM/DVD (I:) : N/A @ LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller
LPC Hub Controller 2 : ASUS (ICH9) SMBus Controller
Audio Device : ASUS (ICH9) HD Audio Controller
Audio Codec : Analog Devices ??? (198B)
Serial Port(s) : 1
USB Controller 1 : ASUS (ICH9) USB Universal Host Controller
USB Controller 2 : ASUS (ICH9) USB Universal Host Controller
USB Controller 3 : ASUS (ICH9) USB Universal Host Controller
USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller
USB Controller 5 : ASUS (ICH9) USB Universal Host Controller
USB Controller 6 : ASUS (ICH9) USB Universal Host Controller
USB Controller 7 : ASUS (ICH9) USB Universal Host Controller
USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : ASUS FW322/323 IEEE1394 OHCI FireWire Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Canon iP4300 (USB, Colour)
Scanners and Cameras
Camcorder : Logitech QuickCam Communicate STX ()
Network Services
Network Adapter : Netopia 3300 Series USB Network Adapter - Packet Scheduler Miniport (Ethernet, 10Mbps)
Network Adapter : Bluetooth Device (Personal Area Network) #2
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 07-14-2008, 12:49 PM
Default Re: 6088 and 9093 errors
I fixed it after goofing around with all kinds of possibilities. I deleted the Acronis True Image "Secure Zone" partition that I had created a little while back to use the "Try and Decide" feature with Version 11. After PT was normal again, I tried the Secure Zone thing again and Windows DID NOT like it. I had to use a previous image to get things normal again.
And the slow draw I had on the menu items was due to the "Display" hardware accelerator being turned down all the way recently as per the Digi troubleshooter post. I turned it back to full and slow draw is gone.
MacBook Pro Mojave
16GB DDR3
6085 and 6088 Errors - Just Started - Sandra Report Included JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-03-2010 03:13 AM
Trouble in 002 Land: 1394 intermittent, --6088, -6085 errors dbrunell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 01-04-2010 10:33 AM
-6088 and -6085 errors, any ideas? BillDog793 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 11-24-2008 12:41 AM
-6085 / -6088 errors caused by bad video monitor daeron80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-10-2007 10:02 PM
Digi 002: Errors -6085 and -6088 zail 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-04-2006 11:02 AM
