PT HD OMF exporting
I am trying to export 4 to 8 tracks of omf audio stems to an ABVB Avid. When I check enforce avid compatibility and embedded media, it seems to go through the process, but when imported to the Avid, only the first second of audio comes over with the file. The clip itself is the correct duration and the size of the files are consistent with the protools files.
Exporting the individual files works fine. Any solutions?
Rick Sanchez http://www.posthastemedia.com MacPro 2x2.66 GHz Dual Core "WoodCrest" Mac OSX 10.5.8 / 4 Gig Ram ProTools 8.0.4 Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro) HD3 Accel BlackMagic Decklink Studio 2 (In Slot 3 of MacPro) SurCode / Dolby Media Meter 2 Izotope RX2 Advanced / Sonic NoNoise Waves Platinum 7.x / Serato PitchnTime Melodyne Studio / Altiverb XL / Speakerphone KOMPLETE 7 EQuality / Massey L2007 TC MasterX |
Re: PT HD OMF exporting
Hi Rick
Are these actual contiguous mix stems, or mixed regions that are seperate? My question is because, if they're actual continuous "whole file" stems then why bother with OMF at all? Just give the picture department the SD2 or AIFF files, they'll import them, done. I'm sure I've mis-understood your question or circumstances- this one seems too easy Hope this helps and does not annoy, |
They are contiguous mix stems and my work around has been to give them the individual files, but they then have to place each file on a track one at a time. Not a real big deal, but if I have 30 8 channel spots, it does add a considerable amount of time to the process. When I export from Audiovision, they can just bring in the 8 channels as one clip. It also would possibly save some user error sync issues.
exporting ? | 2crows | Getting Started | 13 | 08-21-2013 02:48 AM |
Exporting an OMF from P.T | DrDub | Post - Surround - Video | 3 | 01-15-2008 10:58 AM |
exporting a 24/48k to a 24/44.1k | PMoshay | Pro Tools TDM Systems (Mac) | 0 | 04-24-2006 11:09 PM |
exporting omf | canoa | Digidesign Hardware & Software | 0 | 04-24-2002 08:31 PM |
exporting from PT | taccomc | Pro Tools TDM Systems (Mac) | 1 | 04-26-2001 06:12 AM |
