Bounce auto name change, I hate it!
After you've bounced a .wav or a quicktime, the next time you go to bounce something, PT has changed the last number in your filename say, '15' to the next numerical number (16).... SO ANNOYING! Anyway to disable this?
I'm using PT11 D |
Re: Bounce auto name change, I hate it!
I haven't seen a way to disable or change this behavior in PTHD12. I think you either ignore it and run your own naming scheme, or if you have a lot of bounces to do, roll with the default naming system and then use A Better Finder Rename to batch process your bounces.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Yeah, really annoying if you're bouncing out a bunch of files, with a date at the end of the file name - suddenly you've got files dated 2015, 2016, 2017 etc.
I tend to enter the suffix that I want, copy it, and then paste it to the name field, for each file I'm about to bounce. |
Ray Trujillo Freelance Audio Engineer |
Thanks guys.
auto buffer change on play back and record | mikeyman | Pro Tools 10 | 1 | 01-09-2015 10:07 PM |
Midi Auto Release on Bounce | dviv | Pro Tools 11 | 0 | 07-12-2013 12:26 PM |
Pitch change after Bounce | gregtrinity35 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-19-2011 11:55 AM |
I hate bounce to disk! | fixdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-18-2005 06:49 AM |
why does PT auto-change MIDI files?? | tommydee | MIDI | 1 | 02-23-2001 11:28 AM |
