Old 05-01-2010, 06:21 PM
Hanswurstlsepp Hanswurstlsepp is offline
Question Opening track lanes from d-command?
I'm wondering if it is somehow possible to open up a track lane in the EditWindow by using the d-command for that ?
Also, I guess (and hope) there is a way to toggle the EditWindow's track view from a selected track by using the d-command.
I searched the manual high and low but couldn't find it.
Would be great to get a tip
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 05-01-2010, 10:24 PM
GlennR01 GlennR01 is offline
Default Re: Opening track lanes from d-command?
Not yet available. Should be though.
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate
Old 05-02-2010, 09:02 AM
Oh okay. Thx for your reply nevertheless.
Cheers, STeff
Old 05-02-2010, 09:58 AM
Drew Mazurek's Avatar
No way to do the Lanes but pressing Command-Control while touching any parameter will bring its automation playlist into view. Then Command-Contol and pressing Select will return you to Waveform view. Is this what you were asking?
Even without the D COmmand you can hold down all three modifiers and press the left and right arrows on the keyboard to cycle through. Not nearly as cool at the Command-Control touch though.
www.drewmazurek.com
Old 05-02-2010, 11:57 AM
Question Re: Opening track lanes from d-command?
Originally Posted by Hanswurstlsepp View Post
Originally Posted by dmazurek View Post
No way to do the Lanes but pressing Command-Control while touching any parameter will bring its automation playlist into view. Then Command-Contol and pressing Select will return you to Waveform view. Is this what you were asking?.
Yes dmazurek, that was my (2nd) question indeed. Ty so much for helping me !
Yes I know that .... I just did it and I got an Access Violation error while keeping cmnd/ctrl/alt pressed and pressing arrow left/right to toggle thru the different views
Cheers, STeff
opening all inserts command ? athe Tips & Tricks 0 12-15-2009 02:59 PM
Question on new track playlist lanes in PT 8. rdolmat Pro Tools TDM Systems (Mac) 4 10-06-2008 07:33 AM
"select next/previous track" "rec enable track" key command? maufau Pro Tools TDM Systems (Mac) 6 04-22-2008 06:08 PM
Opening DP track in PT flymax Pro Tools TDM Systems (Mac) 4 10-05-2006 10:08 AM
Opening 32 track tdm session on 001? Question 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-18-2002 02:16 PM
