Old 05-29-2006, 07:12 PM
f.R f.R is offline
Default Still DV out firewire problem
well,I've got a Quicktime pro installed,but the menu'Quicktime DV out firewire' is still gray and unselectable.My dealer told me that pro tools 7 does not support this,do I need to find an older PCI-based Powermac and install a pro tools 6.9?Bad idea...
Old 05-29-2006, 07:25 PM
minister's Avatar
minister minister is offline
Default Re: Still DV out firewire problem
hahahahahaha very...
are you going to use the canopus or a camera or something?
what OS are you on now? did you use the combo installer?
10.4.6 COMBO
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 05-30-2006, 03:30 AM
miha78 miha78 is offline
I have the same problem. The menu play out of FireWire port is gray. We are trying to use Canapus ADVC110. We have OS 10.4.6,
hardware wise we have
Power Mac G5 Quad
PowerMac11,2
PowerPC G5 (1.1)
CPU Speed: 2.5 GHz
Memory: 8 GB
Bus Speed: 1.25 GHz
Pro Tools 7.1
I would really apretiate if anyone could help us in this matter
Thanks
Miha
Old 05-30-2006, 06:32 AM
georgia georgia is offline
IF the QT file is not compatable with a DV video stream the Video out option will be greyed out. Check the video stream format and/or convert the QT to a DV stream.
Also, amke sure the ADVC 110 is working properly... They have a funny habit of breaking if you insert or remove the Firewire cable with the Unit turned on. 've had to have mine replaced and I've heard from others including Canopus concerning this.
The menu option will also grey out if your firewire video device in not "seen" by the system.
cheers
geo
georgia hilton CAS MPSE MPE
Hilton Media Management
Film Doctors http://www.filmdoctors.com
Me... http://georgiahilton.webs.com/
Stage 32 http://www.stage32.com/profile/6569/georgia-hilton
My Production Company http://www.hiltonmm.com
CREDITS (partial) http://www.imdb.com/name/nm0385255/resume
MEMBER: IATSE LOCAL 700
Old 05-30-2006, 07:07 AM
minister's Avatar
this is what i was looking for:
from a thread from a few weeks ago :
You didn't say if you had just upgraded to Tiger or not, but if you have, there is a known QT7 bug that comes along with the upgrade. On some systems the QT installer doesn't work right and NO Firewire devices will be recognized by QT. (Got bit with this when I upgraded my home rig). The solution, courtesy of the Apple boards is:
1. Go to /Library/Receipts (your main Library, not the one in the user folder)
2. Remove ALL the Qucktime Receipts EXCEPT the ones that say "Media" at the end.
3. Go to www.apple.com/quicktime and download the STANDALONE installer (do NOT do the upgrade)
4. Install and reboot.
Your CANOPUS should now be seen by PT.
Howard Sonnenburg
Atomic Productions
Ottawa, ON
Canada
Tom Hambleton CAS
IMDb
-Starcrash
Old 05-30-2006, 09:59 AM
f.R f.R is offline
many thanks minister,I'll try it^_^
Old 05-31-2006, 09:18 PM
f.R f.R is offline
bad news I tried everything but nothing gets better.I'm now on MacOS 10.4.6 and PT 7cs7,Quicktime was reinstalled too.It seems that my Pinnacle Moviebox DV won't work on this system,though it worked on MacOS 10.3&PT 6.9
Maybe I shall get a new firewire DV box.Avids cost too much for me,is there any cheaper solution?
thanks for help,minister and all
Old 05-31-2006, 09:23 PM
minister's Avatar
RATS!!
look at Aurora's FUSE-X and PCI card that will play ANY codec and is less than $500 USD. almost no latency -- better than any DV box.
AURORA FUSE X WEBSITE
Tom Hambleton CAS
IMDb
-Starcrash
Old 05-31-2006, 09:41 PM
JSR JSR is offline
...but another slot!!! I wish I had more.
Old 06-01-2006, 12:38 AM
f.R f.R is offline
right,we have only 3 PCI-E slots for HD3!Fuse-X's cool,only if it uses firewire...
Firewire problem peralti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-27-2009 05:58 AM
FW410 Risky Firewire Problem ? or Not ? Firewire risky port ??? jaunmanuek Pro Tools M-Powered (Win) 2 02-24-2009 06:22 AM
Firewire problem on XP Pro MFR Pro Tools TDM Systems (Win) 7 08-26-2006 12:17 AM
New Firewire Hd Problem! StefB Pro Tools TDM Systems (Mac) 2 10-25-2004 04:13 PM
Another Firewire Problem, Help? stainless.steel Pro Tools TDM Systems (Mac) 7 10-06-2003 01:59 PM
