Old 01-26-2020, 02:59 PM
Big Mother Big Mother is offline
Default Re: Importing Audio vs Session Data
As to the second half of your question, about populating a Template with Session Data, does the "Automatically Copy Files on Import" option from the Preferences Processing page work for that?
PT 2023.12 / Mac Mini M1 16gb SSD / OS X 14.2 / UA Apollo
Old 01-26-2020, 03:30 PM
BScout BScout is offline
what gwhatley said is correct.
Use the workspace window.
You can use the sort by path method or, while the drive/audio is offline, in the workspace browser select "all offline". Keep the workspace open, then connect the drive and do a relink, the selection of what was all offline should still hold after the relink, then do a copy and relink from the workspace browser (pointing to your new session folder)
Old 01-26-2020, 03:35 PM
gwhatley's Avatar
gwhatley gwhatley is offline
This is a good point, but I don't believe it has an impact on "import session data". There is a box in the import session data window where you can toggle between copying files on import or referencing original files (and also something like "force to target session format"; sorry, not in front of it right now). Anyway, choose the option to copy the files if that's your preference! It's a big window; lots to miss...
Sent from my LG-H872 using Tapatalk
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
On the Import Session Data window, there's the Media Options section. Just needs to change that from "link to source media" to "copy from source media"
All the options are built right into that window. And that setting will stick until you close Pro Tools down. (so you can open/close/import as much as you want while Pro Tools is open and you don't have to look at the setting until the next time you start up Pro Tools from scratch)
Waveforms increase in size when importing audio file as session data import myeviltwin Pro Tools 2018 4 02-10-2018 02:20 PM
PT 11.3 no longer importing audio files along with session data jsbeeth Pro Tools 11 3 02-25-2017 04:28 AM
Can't find 16 bit audio files when Importing Session Data DavidCaporale macOS 0 04-23-2015 08:50 AM
MBox - importing session data, missing audio!? spike.mk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-08-2009 08:42 AM
Problems importing audio, session data, etc. essay Pro Tools TDM Systems (Mac) 0 09-12-2006 10:18 PM
