Accessing multiple EQs on Artist Mix
The manual is very clear on how to do that:
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
Re: Accessing multiple EQs on Artist Mix
I can confirm this works the way you described...it's not a bug, it's a feature
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
All you have to do is hit the inserts button and then select the eq you want to edit. Easy and just as many button pushes.
Can't say when it will happen. Avid is a publicly traded company and I'd get into trouble. |
Thanks. Read the OP's question and wondered how to do it as well, then read yours and realized, yea.
Please, bring EQ and Dynamics cycling to Artist Series. It's been almost 3 years. Is it still in your backlog?
Does anyone know if eq/dyn cycling has been implemented yet? I am reviving an old thread in the hopes that the feature has been added and I just missed how to access it.
So far I am using the following workaround: The trick is to disable all other plugs but the compressor and eq I want to open when I press the associated button on the Artist Mix. Once it opens the plugin (it won't matter anymore if it is in the first insert or not) EuCon will remember which plugin to open. Then I can enable the remaining plugins once more but the Artist Mix open the plugins that it opened before in EQ and DYN modes. Would be terrific if one could cycle through eq's and comps. |
It's nice that S6 is finally catching up to ICON and it received Cycle function, but why not Artist Mix and S3?
I'm not sure who Artist PM is as that's before my time with Artist Series. They're certainly not at Avid anymore. Now we have it implemented in Pro Tools(main part) it shouldn't be too hard to port to EuControl.
PT crash when accessing Slate Trigger 2 from Artist Control/Mix | ThomasHQ | Artist Series | 2 | 01-20-2014 12:54 PM |
Artist mix: use multiple faders simultaniously | Toto2004 | Artist Series | 4 | 05-28-2013 05:51 AM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
Using Artist Control with Artist Transport? | GrievousAngel | Windows | 2 | 03-14-2012 03:29 PM |
Accessing ilok.... | Hal Boudreau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-27-2011 07:42 AM |
