Old 02-02-2010, 05:27 AM
ionStorm ionStorm is offline
Default Some questions on SC48 and Protools
Hi! I'm new to the forum. I'm from Malaysia and i'm currently testing out a couple of mixers to see which one suits my church best (we're getting a new one!).
I had the opportunity to use it live for my weekend service and it ran without a hitch. There were however some things that I couldn't do and I was hoping I could get an answer in the forum.
  1. Is it normal to be running at 60C? I'm quite worried that this might reduce the SC48's lifespan.
  2. I learnt that the SC48 uses a regular HDD (2.5"?) to host the OS and some other files. Is it possible to change this to an SSD? I work with computers alot and HDD's fail all the time. I'm also hoping that an SSD (like an Intel X25-M) might allow the console to boot faster.
  3. Is it possible to playback via Firewire from a typical player (ie. iTunes) while recording in Protools?
  4. I don't fancy a Mac. Maybe I haven't got used to it yet but can I get the SC48 to run on a notebook with Windows 7, and use Protools? Preferably without any headaches involved.
  5. A number of my friends have raised an eyebrow at Windows XPe. Is it possible for the SC48 to get infected with typical thumbdrive viruses? Also, with enough effort, is it possible to introduce a virus/trojan into the SC48?
  6. Remote controlling the SC48 over WiFi was a really lousy experience using Ultra VNC. It was laggy, and the meter updates are slow. I'm using an old Pentium-M laptop. I'm running on 54G. Is that sufficient, or am I just doing it wrong?
  7. Is it easy to replace a module in the SC48? My dealer/supplier says that Digidesign does not do repairs. The "Hardware Assurance" plan also seems a little expensive and out of reach.
Also, another two things that would make it better for my volunteers...
  1. Will Digidesign ever implement a way for the SC48 to switch back and forth between FWx and Stage Inputs, just like how it's done with HDx? I don't think it's impossible. We would just need to specify the channels that the SC48 should be tracking.
  2. Will Digidesign ever implement user management features like the M7CL? I need to lock out the options page from newbies. Who knows what they might mess up? I had a friend demonstrate to me some wonderful event triggers that wreaked havoc on the board.
Sorry to be coming out of nowhere and asking so many questions. We will be making a decision about which mixer to buy in about two weeks, so I need to get informed...and quickly.
Thanks in advance!
EJ
Old 02-02-2010, 08:42 AM
noclevername noclevername is offline
Default Re: Some questions on SC48 and Protools
The answers I can help with are in blue
    I'm sure the monitoring system would warm if there was a problem.
    There has been a bit of discussion about that. See this forum...http://duc.digidesign.com/showthread...SD+Solid+State
    Yes, you need the core audio drivers and you can then patch the firewire input on your console to tracks 1+2
    Yes, this is a cross platform program that runs a VNC. Win 7, Vista, XP, or mac or iphone will work. Do you mean the offline editor? That is Windows only. Protools LE is cross platform though.
    Anything is possible, but since it is XPe, the odds are greatly reduced. I heard about this happening on a lighting console running XPe, but it was an isolated incident. I have not heard of this being a problem on the forum at all. The moral is if you are worried, run a scan on your laptop or such before sticking it in your console.
    Faster is better. I run a 54G network and run into the same thing. Make sure the laptop has plenty of ram, and think about upgrading to a "n" wireless. I've heard that is much faster. Otherwise a hardwire ethernet connection would probably be very fast.
    Not sure about this one. I have the mix rack which was not too difficult.
    Suggest this on the feature site. I agree with you! http://avid.venue.ideascale.com/
Thanks in advance!
EJ
Brian Webber
First Covenant Church
http://www.firstcov.org
Sacramento, CA
Old 02-02-2010, 03:38 PM
I've already tried that. I am using the Core Audio drivers, but I can't do both things simultaneously. I want to know if simultaneous operation is possible.
I'm a little concerned about getting it to run on a PC notebook, judging from all the horror stories i've read.
I couldn't get any audio out of a notebook I tried. Granted it's an old notebook (Dell Inspiron 510m I think), but it was using Windows XP and had a TI firewire chipset. I installed the standalone ASIO drivers (it used the Digidesign Firehose driver). I was trying it out with Sony Vegas/Acid. It just kept telling me there was no device connected.
I don't think upgrading the laptop is going to change anything. I believe the issue lies in how VNC transmits data. Gotta wait for Sheldon to reply this one...
Old 02-03-2010, 04:31 AM
digidesigner digidesigner is offline
VNC on my Mac laptop is slow but the hardwired PC at the same network in the other hand is very fast controlling D-Show
Old 02-03-2010, 09:16 AM
Mike Z's Avatar
Mike Z Mike Z is offline
As you discovered, simultaneous operation is not possible as the FWx driver is not multi-client. You would either have to close Pro Tools to switch to the Core Audio drivers, or import the tracks into Pro Tools for playback through FWx.
SC48 Basic questions [email protected] VENUE Live Sound Systems 1 05-21-2011 06:53 PM
Couple of additional SC48 Questions! Limelight VENUE Live Sound Systems 1 09-24-2010 11:03 PM
2 SC48 Questions Limelight VENUE Live Sound Systems 5 09-09-2010 07:15 PM
SC48/LE firewire rookie questions Jonathan K VENUE Live Sound Systems 7 04-04-2010 04:59 AM
SC48, some questions, some answers ? Nicolas Haber VENUE Live Sound Systems 3 12-06-2009 01:45 PM
