Old 09-24-2007, 09:50 AM
U2502 U2502 is offline
Default Restore Corrupt Audio Files?
Hi there,
A friends of mine was recording 2 tracks to his mbox and his computer locked up. We can see the audio files on the drive but protools will not open them. He was using PT 7.0. I have told him to upgrade to 7.3, which would help with this problem, but I am wondering if there is anything that we can do in the meantime. It seems as though the headers are corrupt. Is there any way to remove the headers from the file and rewrite them? Any help would be much appreciated. Thanks.
--micah
Old 09-24-2007, 10:09 AM
Roey Roey is offline
Default Re: Restore Corrupt Audio Files?
Both WAV and AIFF are RIFF files meaning their headers are freely available over the net (check out http://www.sonicspot.com/guide/wavefiles.html). Most likely, Pro Tools either didn't write the header, or it wrote the header but didn't fill in the file (chunk) size. Basically, the headers of all files recorded in Pro Tools are similar, with the exception of their size fields (respective to the file size). The header size is constant (it is than followed by the audio data).
Best way to go about this is get another file that was recorded properly with Pro Tools, simply copy and paste the header, then change the size fields. You can easily find the places need changing by comparing two, properly recorded files of different sizes.
To be sure, work on copies of your corrupted files. You will need a HEX (or Binary) editor. I know that for PC there are more than a few freewares. Here is one for a Mac: http://www.apple.com/downloads/macos...ools/0xed.html
It should take a minute to someone who knows how to hack binary files.
Cheers,
Roey
Roey Izhaki
Author, Mixing Audio
Old 09-24-2007, 10:23 AM
One more thing...
The files that you see on the drive, do they have meaningful names (like Audio1_01.wav) or is it gibberish (like zyhdjdjfj).
If its a meaningful name than the (empty) header should be allocated at the beginning of the file and you need to do what I've said in the previous post.
If its gibberish, I'm pretty sure that this is pure audio and you'll need to ADD a header before the information you already got on the file. This can be somewhat more tricky.
By the way, 99.9% that upgrading to 7.3 won't help your friend.
Cheers,
Roey
Roey Izhaki
Old 09-24-2007, 10:54 AM
James Drake James Drake is offline
http://duc.digidesign.com/showthread...Number=1200271
Waves Plugins FOR SALE
corrupt audio files PT 8.0.3 kava Pro Tools TDM Systems (Mac) 157 02-21-2021 08:46 AM
corrupt audio files? active Pro Tools HDX & HD Native Systems (Mac) 3 08-12-2012 12:24 AM
corrupt audio files PT 9 Pro Logic Pro Tools TDM Systems (Mac) 2 02-16-2011 02:53 PM
My Audio files were deleted!!! What software to buy to restore the files.... lucio matarazzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-22-2000 06:45 PM
corrupt audio files please help tomcat Pro Tools TDM Systems (Mac) 4 06-05-2000 01:42 PM
