Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 12-01-2016, 01:58 PM
SIU Telehealth SIU Telehealth is offline
Default PT First Crashing on Startup
So, I've rarely worked with Pro Tools First, I have it personally at home, and don't use it due to issues installing. I have it here at work because Audacity doesn't like the number of inputs we have.
I have it installed and was able to open it once, now it gets stuck on initializing database and CTD. It rarely get's passed this point, but when it does, it goes through most of the startup and then CTD.
I am running a new, powerful gaming rig that has: i7-6700, 16GB RAM, Win-10, nVidia GTX 910. With a Scarlett 18i8.
After checking the event viewer I am finding AppHang's and DLL errors. Any input or advice is greatly appreciated, as we'd rather not have to purchase a new recording software.
Old 12-01-2016, 04:54 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: PT First Crashing on Startup
Please take a look at the Help us Help You thread, which has general setup, optimization and troubleshooting tips. If that doesn't get you going, post a system report, which will give us some insight into your system.
One thing you can try is holding down the N key while PT is loading, which will reinitialize your IO settings.
Will K
System Details
Old 12-09-2016, 09:49 AM
I read through the Help threads and unfortunately none of it applied. At this point it's just flat out unusable. It CTD during the loading process; and at different times: when initializing Database, Plug-in's, when attempting to sign-in to our account.
My hardware is listed in my first post.
Old 12-19-2016, 08:25 AM
Mariwa Mariwa is offline
You're connected to internet when opening PT First right?
It won't work if you're not connected.
pt 11 crashing on startup lucidlife macOS 6 01-03-2015 09:41 PM
PT 9.0.5 Crashing on startup!! eanderso22304 macOS 3 10-05-2011 11:31 PM
Pro Tools 7.3 LE keeps crashing on startup!! RP89 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2010 05:17 PM
LE 8.0 crashing on startup jbeband 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-23-2008 11:00 AM
PT LE Crashing on Startup beggehorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-18-2006 09:18 AM
