Old 05-14-2012, 02:16 PM
Luis Carrillo Luis Carrillo is offline
Default Share some tricks i7 750, 760, 780
Hi everyone, i opened this forum to share some tricks for performance, and read some from other people that has the same system.
Here is my system:
GA-EX58-UD3R (rev. 1.0)
i7 950 quad
16 gb ram kingston 1600
win 7 pro
magma chasis 13 with pcie host card
1 core hd card pci
1 accel card pci
1 process card pci
protools hd 10 10.1.2
uad 2 solo card
waves platinum, ssl,
mcDSP
SSlate mastering,
Sonnox Reverb, eq w/GML, Inflator, Trans,
melodyne editor
Old 05-14-2012, 02:19 PM
Default Re: Share some tricks i7 750, 760, 780
Here is one that may help some one, setting up the cores for protools as low as you can will leave more process to the plug ins to work better, sounds not right but in my experience my system works a lot better with 2 cores (85%) for protools than increasing them (4 cores or more).
Old 05-14-2012, 02:26 PM
Here is Another:
If for some reason i have to insert a RTAS plug ins where i already have TDM plug ins, ether change the TDM to RTAS or Viceversa. but leave on the line just one kind.
Old 05-14-2012, 03:03 PM
Shan's Avatar
Shan Shan is offline
This is pretty generalized. Can you expand on this with the "why" and more details. Many will disagree with this one.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 05-14-2012, 03:10 PM
Since you have a mobo that can run triple-channel RAM, you should try removing 1 stick(from the blue slot) and running 3x4 in triple channel mode. It will likely give you better performance than 16GB of RAM(that's NOT running properly). Then retest your core theory(how many cores give the best result). In general, 1 less than the total number is the "happy" spot(for most users). For me, it has always been all cores, but some VI plugins seem to steer it otherwise. AFAIK, the X58 motherboards are the only ones that offer triple-channel, so start there Other motherboards, check your manual.
Old 05-14-2012, 04:14 PM
Shane
Well im sorry for been generalized. For some reason i understood wrong the set up on protools and thought that increasing the cores for protools would increase the performance, but trying different settings and reading more about it, i ended up setting as less cores as i could for protools, but i dont know how many you r going to need because it now depends on your plug ins, or instruments.
Old 05-14-2012, 04:24 PM
Thank you for replying, now i thought the same thing before untill i started having problems with two different plug ins, UAD-2 and Native Instruments, and i ask both of the companies about the problems, (insuficient CPU, increase buffer size or reduce RTAS plug ins ETC) and both of the companies say that i have to leave some power for the plug ins, NI have a menu where you select how many cores you can dedicate to your instruments (kontakt Strings pro) and actually how much memory and also i have to move that to get the best performance.
For UAD, all they said it that try to decrease the number of cores, starting with 1, then increase it until the problem starts, and when i did that, the problem started at 4 cores, so i ended up using 2 cores and the problem went away.
Old 05-14-2012, 04:27 PM
Go here for i7 performance setup optimizations. This road has long since been paved. Just follow the footsteps.
Shane
thank you
Old 05-14-2012, 04:29 PM
I got the taking out i memory from the blue slot (thats very Interesting), but "running 3x4 in triple channel mode." i didnt get that. Thank you.
Old 05-14-2012, 04:35 PM
Also im trying again 7 cores 85%(for me -1 total cores)at 512 buffer size, i'll let you know how it worked. thank you.
Share some tips and tricks for mixing TV! arvid.lind Post - Surround - Video 15 07-13-2006 08:44 PM
any drum edit tricks to share? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-24-2004 02:58 PM
Share your tricks on Comping KingFish Tips & Tricks 5 02-01-2004 01:44 PM
low end tricks troswalt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-29-2003 02:27 PM
Mix Tricks pookadilly Pro Tools TDM Systems (Mac) 10 01-08-2003 12:05 AM
