Re: UAD Console & Protools BEST PRACTICES
I have 2 Apollo 8Ps that I lightpipe into an HD Native PCIe rig. It's like having an amazing $6000 sixteen channel SSL console to track through. Been using the real ones since the early 90s. Sure I have to be careful about latency and use Slates plugs during tracking and overdubbing. But it forces you to get good sounds going in, like the old days. My work has never been better.
As a composer type dude I like to track with EQ and comps but not commit because like a lot of guys, I'm usually concentrating on composing and/or playing.
Dave Marsden UK |
I do a similar thing to Drew. See my sig.
It really does give you the best of both worlds in HD Native. I simply use the Apollo's as outboard light piped into the 8x8x8. I find that tracking with the UAD Console is very good with little audible latency. Tracks are always aligned correctly. It's a very workable solution. John
PT 2021.12 Native 2x Universal Audio Apollo 8p and Apollo 8 Mac Studio. M1 Max. OS Monterey 12.3 Avid S3 and Avid Dock. Dynaudio BM5's. |
Let me get this straight.... when you drop in, (or punch in as you guys across the pond would say,) you have to manually switch the monitor source from Pro Tools to the UAD console and back again when you drop out? Really?
Dave Marsden UK |
If using UA's Console, you put PT in LLM and PT handles the muting for you. If monitoring through the DAW (at a low buffer like I do) it's just like using a console and a tape machine. The only downside (for the engineer) is that with method 1, during pre and post roll you will hear the previous performance and the live mic signal. This is actually a desirable thing for most musicians however as it's reminiscent of SSL's SuperCue™ system found on the big consoles. |
Yes. I'm using PT on low buffer & Console is just the front end. I find the Supercue vibe strange to work with, although that could just be habit & being accustomed to not hearing live input during pre roll.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Dave Marsden UK |
Yes, Console is a virtual front end. A tracking console if you will. And yes, you can choose to just monitor with processing or commit to tape (or both!!), on a channel by channel basis.
SSL's Supercue only fed both input and monitor to the Cue Send for the artist, and not the monitor path for the engineer, so it was superior. Of course this can't be done now due to latency. |
Yes but, I find that say with a drummer they'll play along but be playing harder to hear their live input above the playback so when the drop in happens there's a mismatch …
maintenance best practices? | timebandit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-08-2012 03:35 AM |
Playing Nice: ProTools 10 and OSX: Set up, Best Practices and Maintenance some Info ( | epiphone | macOS | 5 | 02-28-2012 04:42 AM |
Software Updates - Mac OSX and best practices | OneMadSon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-26-2007 06:03 AM |
OS Updgrading Best Practices... | proxy | Pro Tools TDM Systems (Mac) | 6 | 09-16-2006 06:46 AM |
Practices Sessions | robertstj9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-01-2005 09:35 AM |
