Old 01-13-2023, 07:07 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default Playback stopping when ..
Prior to Monterey I always left ichat, safari and mail running in the background with no affect on PT. All apps needed for business. However first with Monterey, and now more so with Ventura, Protools playback stops / errors when a mail or message is received and when any webpage with any playback draw is loaded. System usage is all under 30%. Interestingly - I was able to record 160 tracks over 12 x 1-2 hour sessions without interruption. This only occurs on playback and with moderate plugin load. All systems settings as per PT install instructions. Of course I can quit those apps, and I do when it gets ridiculous - but I'd LOVE to know if there's anything I can do - seems to me the processing power is not the issue. Some kind of interruption going on. System sound is set via the 4K monitors speakers.
HDX1. MTRX / Dadman (current) PT Ultimate 2022.12. MBP 2019 64GB Ram. Ventura 13.0.1. Caldigit TS3+
Any ideas?
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 01-13-2023, 08:17 AM
huzzam huzzam is offline
Default Re: Playback stopping when ..
ha iChat, you're showing your age :) (and so am i, for recognizing it)
just a shot in the dark, are Mail/Messages set to make a sound in the Notifications settings? perhaps the audio (which might be at a different sample rate) affects the sync of interface / pro tools?
as for safari, are you running any extensions which could be causing high system load?
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 01-13-2023, 08:18 AM
its2loud its2loud is offline
just a shot in the dark, are these apps set to make a sound in the Notifications settings? perhaps the audio (which might be at a different sample rate) affects the sync of interface / pro tools?
This is the nail on the head.
Old 01-13-2023, 08:40 AM
AINSLIE's Avatar
I actually have all notifications off for all those apps (in system settings) - and pretty much everything except ProTools!. Also just now turned off 'play user interface sound effects' in the sound tab. Also sample rate (48K) is same as what I generally work in .. and finally there's a preference under 'general' in Mail which had sound notifications in addition to the system wide notifications panel - DOH! Disabled. I really hope this solves it ... Thanks a ton!
Old 01-16-2023, 03:13 AM
CraftWW CraftWW is offline
Any ideas?
The same here. On Monterey it completely hung up pro tools and its aux i/o.
Now on Ventura it´s stopping its playback until the aux i/o is resynced.
Interestingly it´s the same with other virtual interfaces like source nexus.
I´m going crazy....
Did you find a solution?
I already don´t generate any system sounds anymore, but there is always an app that does some audio and brings me down ...
Old 01-16-2023, 04:01 AM
It seems like I´ve found a workaround.
In the audio-midi-devices set the interface for system sounds to mute.
This way Pro Tools doesn´t stutter anymore.
But this is just a workaround......
I would definitely like to know what is causing the hiccups
Old 01-16-2023, 07:53 AM
AINSLIE's Avatar
Great idea - for me simply muting the mail notifications sounds in the Mail app solved it. I had already muted all notifications in system settings. I may toy with turning the not sound notifications back on tho ...
File Type: jpg Screenshot 2023-01-16 at 9.50.01 AM.jpg (41.7 KB, 0 views)
Old 01-17-2023, 02:58 AM
I tried all Pro Tools versions since 2022.9 now prior to a clean uninstall.
All behave the same.
I also tried different I/O interfaces. I have a license for Source-Nexus I used before the intorduction of Aux I/O.
Exactly the same behaviour!!!
I think it has to do with the OS and the 2019 MacPro hardware.
Even when audio of the system is muted and I just click on the audio menu entry in the system settings of macOS -> it stutters. It seems like an interface event or activation that triggers the stutter.
Same on Aux I/O. When I´m playing back s.th. on one interface and activate another one for client audio i.e. playback also stutters.
I think it´s a system bug....
Old 01-17-2023, 04:07 AM
Here is another hint:
https://www.reddit.com/r/MacOS/comme...dio_interface/
Old 01-18-2023, 02:27 AM
I found a little workaround so that my main desktop bridge interface keeps playing audio flawlessly ...
In Ventura there is an Accessibility setting where you can generate relaxation sounds. I put it on uniform noise (translated) and dimmed it completely (no sound at all) but it keeps the interface active
FX propagation after stopping playback kirkbross Pro Tools 2019 1 01-12-2020 08:04 PM
Random stopping of playback... 12.8.2 R2 SevenRising Pro Tools 12 0 10-20-2017 12:15 PM
Skipping playback (stopping/starting during playback) sKjF Pro Tools 12 12 11-12-2016 06:28 AM
Playback/Recording stopping immediately newaudiogirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-06-2007 10:57 PM
Stopping playback returns transport to zero? TimInVan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-13-2002 04:49 PM
