Digidesign 002 to pro tools 10
So I have an old digidesign 002 and I got pro tools 10 and hooked it all up to my windows 7. According to the manual and what I've seen, if the settings are right, the 002 should just go into pro tools mode when connected to the computer. Stand-alone mode works fine, but it won't enter pro tools mode. I have the 002 hooked up to the computer and it recognizes it, but pro tools mode still doesn't work. What am I doing wrong?
Re: Digidesign 002 to pro tools 10
You say Pro Tools doesn't work, explain exactly what is happening. Have you looked in the Playback Engine menu and selected the 002?
I just mean that pro tools MODE doesn't work for my digi 002- when i enter pro tools on my computer, the 002 doesn't enter that mode. But you're probably right because when I look at the playback engine the only two options are "SB Audigy 2 ZS ASIO [E000]" and "Creative ASIO" with the default set at the first. I don't see the digi anywhere on there- does that mean I installed the two incorrectly?
The FW 002 (separate) driver after PT's install.
http://avid.force.com/pkb/articles/d...02-003-Drivers
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
After you install that driver and restart, please let us know if your issue is resolved.
When you turn On the 002, Host 1394 must blink at the front of the panel. when you set up the 002 with pro tools, flash light turns on; is not an automatic setting on Pro Tools, You have to Set Up, Another way the check If your System see the 002, is on the Windows sound system, Playback devices, must be there 002, if not, check the firewire cable, or where you connect the interface, Remember that, 002 can't be install on firewire Hubs, maybe check if you change the firewire connector on the back of the 002, to the other firewire port.
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life |
Sorry it took a little while for me to do- I've been a little busy- but yes, TOM@METRO, that worked fine and everything seems to be functioning properly. Thanks!
Great.
Tom, you seem to have the knowledge for this. I have PT MP9 and a Fast Track Pro. I wanted to upgrade so I bought an 002 console. I have since figured out that that combo won't work for some reason. What is my best choice? Go to PT10 but not upgrade to 11? Thanks in advance for your help.
digidesign pro tools set up and 002..help | Daddo71 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-06-2011 11:04 AM |
Pro Tools LE 7 and Digidesign 001 | crashman2u | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-07-2009 09:00 PM |
Is Digidesign Pro Tools changing to Avid Pro Tools? | Shan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 102 | 05-14-2009 02:53 AM |
Digidesign 002 w/Pro-Tools LE 6.7 Set-Up Help | Rick39 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-07-2005 03:36 PM |
DIGIDESIGN PRO TOOLS V.7.0 | darkglass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 102 | 07-27-2005 04:28 AM |
