Adjusting sends pan and send volume goes to zero..
How am I going to be able to adjust sends pan from artist mixers without reseting sends volume?
Same thing on control and mix. Mavericks PT11.3.2 Eucon 3.4
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T HD native thunderbolt PT10HD 10.3.8. - PT11HD 11.3.2 2xHD madi - 2xHD omni - |
Re: Adjusting sends pan and send volume goes to zero..
And the same thing on the S3. Very annoying!
What are the steps to make this happen?
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Go inte sends, and if you have a stereosend, press the encoder to go into sends pan mode, you can now adjust sends pan but now you dont have any volume of the send anymore. Tried it on PT 12.5 today as well, same thing.
And also.. i can not opt + touch a send encoder to get it to unity gain anymore, but maybe that is some kind of preference setting that I can not find.
Also, the option + touch resetting send to -inf instead of 0db is already logged. Thanks,
has the send pan issue been fixed yet? i'm on latest eucon software 3.6 w/artist mix firmware 1.5.1.0 (it's borrowed so i don't want to mess with update in case the owner has it that way for a reason)
i just experimented with the same thing on pro tools control app for ipad. same result. when touching the name of a stereo send above the volume slider send pan becomes available at slot 8 but send level resets to default. i'm gonna guess that pro tools dock is same deal as well. c'mon guys!
This is already fixed in PT 12.8 in a couple of weeks.
one more on the sends: after writing send level to a track in trim mode (during playback or using write to commands), that track gets out of trim mode. (on the S3 that is. Works fine on d-command, haven`t tried this on the Artist series)
Adjusting automation volume by 1dB in PT 10 | cristol2k | Pro Tools 10 | 10 | 01-17-2018 04:04 PM |
Adjusting Playback Volume | plums | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-11-2007 09:42 AM |
adjusting volume automation | euphjazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 12-29-2005 07:40 PM |
adjusting region volume | tokyofan | General Discussion | 1 | 07-11-2004 11:18 PM |
adjusting volume | coreybox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-19-2004 04:53 PM |
