Pro Compressor side chain bug
Can anyone confirm if this is normal behaviour or a known bug. Procedure is as follows;
1. Place Pro-compressor on a track/aux insert. Label as track A 2. Create a side chain bus for the compressor side chain input. 3. Set compressor to ext side chain trigger. 4. Send another track/aux (Track B) to the side chain bus to trigger the compressor. Observed and desired behaviour; When compressor detects signal from Track B in side chain the compressor activates and works normally. When the send on the trigger Track B is muted no compression takes place and Track A is unaffected. Observed and UNDESIRED behaviour; When the send on the trigger source, Track B, is made INACTIVE the compressor behaves as if there is no external side chain and compresses the signal on Track A regardless.
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
Re: Pro Compressor side chain bug
i think when the send is inactive then the key input is also interpreted as not present by the plugin, so the compressor works as it should. Did you try it with a different one?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
A different plugin?
Yes, any other comp with SC will do, the stock compressor/limiter for example
I don't believe that would make much sense. After all, the compressor side chain gets its input from a bus, not from a track. So making the track inactive shouldn't deactivate the bus. What happens if you send 2 tracks to the side chain bus? I.e. add an empty track C, send it to the SC bus as well. Then make B inactive while keeping C active.
SC triggers a compressor based on input signal, and deactivating a single send feeding that SC would be the same as "pulling the plug", atleast in my mind. If you send a second empty track to the same ACTIVE bus, the compressor will not compress.
Just to clear things up a bit. When the send on the trigger track is deactivated the problems occur. If you create an empty track below with an active send it makes no difference.Screen Shot 2017-05-12 at 12.02.28.jpg
This seems to happen irrespective of plugin type. If I mute the send then the VCA in the compressor/gate is not active and signal flows through it un-affected. Desired. But if I de-activate the send the VCA is triggered by the input signal to the plugin even though the trigger source is still selected to external.
So the OP is absolutely right. This behavior is incorrect. |
Creating a side chain compressor | lownotesinc | Tips & Tricks | 10 | 02-09-2012 01:40 AM |
Is it possible to side-chain an EQ? | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2009 06:00 PM |
Compressor side-chain how to? | porkipine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2008 09:34 AM |
How do I set up a Side Chain | junglelabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-30-2007 10:49 PM |
SIDE CHAIN EQ+COMPRESSOR COMPRESSING VOCALS | mihau | Tips & Tricks | 2 | 10-19-2002 01:17 PM |
