Old 07-07-2008, 07:05 AM
soundguydave soundguydave is offline
Default DV Toolkit 2 not working with 7.4.2?
Trying to run 7.4.2 on OSX 10.5.3 on my macbook pro with DV toolkit 2. When I install the software (protools and DV toolikit) it launches and works fine. As soon as I quit the program and try to open it again, it will not make it through the boot window. If I reinstall everything again it works, and then as soon as I quit and relaunch, same thing.
Dave Kaduk
Particle Audio
Old 07-07-2008, 09:17 AM
Slim Shady Slim Shady is offline
Default Re: DV Toolkit 2 not working with 7.4.2?
Did you download and installed the 7.4.2 versions of the DV Toolkit? It's working fine here.
Old 07-07-2008, 09:55 AM
the only version I can find on the site is from November 2007
Dave Kaduk
Particle Audio
Old 07-07-2008, 10:20 AM
Avid's Avatar
Avid Avid is offline
Administrator
DV Toolkit 2 Downloads:
www.digidesign.com/support/dvtk2
Pro Tools LE & M-Powered v7.4 & 7.4.2 Optional Toolkit Installers
http://www.digidesign.com/index.cfm?...4&itemid=28388
DV Toolkit 2 v7.4.2 (Mac OS 10.5.3 only) Supports Pro Tools 7.4.2
Administrator
Old 08-18-2008, 05:55 PM
Default
I still cannot get DV Toolkit 2 to work. I downloaded all the recent updates and it just will not launch. If I keep the key out and quit DV Toolkit when it asks for authorization, then put it in for everything else (digitranslator, TL Space, Etc) it loads fine. Running 7.4.2 on Mac 10.5.3
Dave Kaduk
Particle Audio
Old 08-19-2008, 08:00 AM
DigiTechSupt's Avatar
Default
Have you tried trashing preferences yet? If not - start there.
If that doesn't fix it, I think you should try a clean uninstall and reinstall of Pro Tools and the DV Toolkit. Also make sure your PACE drivers are up to date - http://www.paceap.com/
Avid Audio Tech Support
Support FAQ
Old 08-19-2008, 11:47 AM
Default
I'll double check the pace thing. I noticed it works if I leave the key out, and then plug it in and authorize DV Toolkit manually.
Dave Kaduk
Particle Audio
Old 08-20-2008, 06:02 AM
Default
Installed the latest pace drivers and deleted all the digi related prefs and it all loaded up fine. Quit and tried to relaunch and same problem. So If I delete all the prefs, it works fine but the second time I try to load the application, it quits. Same thing happens with a fresh install of protools and DV toolkit and happens under different users.
Dave Kaduk
Particle Audio
Old 08-20-2008, 01:17 PM
Default
I think we need to do a manual uninstall of all the PACE/iLOk components and reinstall them.
1) Download the latest pace drivers from paceap.com (there is a pull down titled, "download drivers" for your specific platform).
2) After downloading, run the uninstaller and Restart the computer.
3) Delete these files:
HD > System > Library > CFMSupport: "InterLok Engine"
HD > Library > Application Support > "PACE Anti-Piracy" folder
HD > Library > StartUpItems: "PACESupport"
4) Empty the Trash and Restart.
5) Re-install the latest PACE drivers.
6) Restart the computer.
Support FAQ
DV Toolkit 2 not working on Mac... grr aprilpsw Post - Surround - Video 4 10-21-2008 11:41 PM
DV Toolkit 2 not working on Mac aprilpsw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2008 03:34 PM
my dv toolkit 2 doesnt seem to be working right with 7.4.2 MASTERLINKSTUDIOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-15-2008 12:46 PM
How is DV Toolkit 2 working out? Hype 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-20-2006 08:26 AM
mp3 option not working with dv toolkit 2 mnoxious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-27-2006 09:19 AM
