PT 12 startup issues [SOLVED]
I have just install PT 12 and have problems already. could anyone please advise me what the correct action for this message? Could not create a new document because Assertion in "/Volumes/Development/158347/ProTools/DFW/Views/UMenu.MacOS.mm", line 1624. PLus I have an issue with playback engine does not support a sample rate of 0 kHz? Thank you G |
Re: PT 12 startup issues
Sorry, should have payed around a little before posting :)
All Fixed |
And for others with these problems, how did you solve them?
Thanks,
Re: PT 12 startup issues [SOLVED]
Same here...
Matteo FasterMaster Cifelli Producer-Engineer |
Something like "no playback engine selected"? Those cryptic "assertion"-messages don't help at all.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Not working ...i have uninstalled PT12.3 , preferences etc etc.
I'm using Digigrid. Any suggestions?
Is there a reason my sample rates aren't supported?
Because your clock is wrong......
(See what happens when you don't give enough info up front??)
Please help
"No se ha podido cambiar crear documento nuevo porque Assertion in "/Volumes/Development/158347/ProTools/DFW/Views/UMenu.MacOS.mm", line 1624." I have this problem with my Mac OS , I have a M AUDIO FAST TRACK, Do I need some special configuration for that.? ( |
Issues with MBox 3 Pro startup | dscheidt | FireWire & USB Audio Interfaces (Mac) | 7 | 11-11-2013 08:09 AM |
Pro Tools 11 Student Upgrade Issues On Startup Launch. | mm9135a | Pro Tools 11 | 4 | 08-21-2013 04:06 AM |
Multiple issues with PT9 - Access Violation on startup plus cascading C++ windows | zorkiii | Windows | 5 | 02-27-2011 12:01 PM |
SC-48 Startup Issues | Paul Peters | VENUE Live Sound Systems | 2 | 02-10-2010 09:11 AM |
Audio engine play startup deadline and other issues | mellow1998 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2009 10:27 AM |
