Profire 2626 and M-Powered 8
I just got the profire 2626. I hooked everything up and installed the most current drivers last night. I have my MPC2000 going into inputs 1and2, my Motix XS6 going into 3and4, and a mic going into 5.
The problem is when I press record on a track in protools it is picking up a signal in the meter, but I can;t adjust the input levels with the profire 2626. The master volume knob adjust the overall volume coming out of the speakers, but does not effect the input levels. In other words when I turn down the volume knobs for inputs 1 and 2 it would not effect the input signal. Why would this be. Is there something to adjust in the M-Audio control panel? I messed around yesterday for a while and could not figure it out. I am running a Macbook White 2.0 4GB. OSX 10.5.6 Any info would be greatly appreciated. thanks!!! |
Re: Profire 2626 and M-Powered 8
I have that identical setup. If you're using XLR conection on the combo jacks then the gain switch is active, if you're going in with TRS or TS through the combo jacks you bypass the gain knob and gain is controlled from whatever is plugged in since it's a line level signal.
Hope that helps |
With line level, you control volume from the source (MPC/Motif)
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
[QUOTE=audiogeekzine;1363261]With line level, you control volume from the source (MPC/Motif)[/QUOTE
thanks! I appreciate the help. I have everything hooked up with trs so that explains it. I'm going to switch to XLR. i prefer using the interface for input levels. Thanks again!!! |
What can I do in the case that I can barely hear the Motif. I have the volume cranked all the way up, and I can barely hear it, and there is a weak sifnal going into Pro Tools. It peak at around -20 depending on the sound. How can I bring this up? I have everything line level. if I get XLR's would this help in this case? Thanks in advance! |
to be honest, you might find simply normalizing the printed tracks to give you better sound than running through the 2626 preamps via XLR jacks.
Most likely the keyboard makes more noise than the converters do at line level, so you won't be sacrificing dynamic range while recording at 24 bit. But if you want to monitor louder etc. then yes XLR cables is the way to do it. To save money, they did the XLR vs. TRS way of switching preamp bypass rather than a separate switch with combo jacks (better) or using a DSub connector for the line ins (the professional approach). |
You shouldn't go direct from the Motif into the XLR inputs on the 2626 unless the motif has low impedance XLR outputs.
What you should use are direct boxes between the Motif and the 2626 - 1/4" out of the Motif to the 1/4" inputs on the direct box, then XLR out of the box to the XLR inputs on the 2626. This will give you the proper impedance at all inputs/outputs. |
Probably the impedances are AOK going ts to XLR as well...you can see for yourself what works best. |
using the LINE input. This is why your only option for gain is the Motif on-board volume. I had the same issue with a drum pad set i was recording. maxxed out volume only gave me -20db to -15db signal input. I used the fader on those channels in PT to increase the volume there are other methods as described above... alternatively use another gain stage.. i was thinking of inputting into a mixer, add some gain and then input into the PF2626, but i have not tried this yet.
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8 |
or just buy a d/i. The profire bypass the pre's and gain knob (which has its flaw) but it lets you hit the converters directly. If you have all 8 out on your mpc then run those to the 2626 and for $150 you can get the ada8000 wordclock it the profire and hook up the rest of your units to that which also has gain knobs which I utterly will say its a good sounding piece regarding what you hear.
WENT FROM HD TO M-POWERED
M-Powered 8 BUG - ProFire 2626 - VID | JVonD | Pro Tools M-Powered (Win) | 3 | 10-21-2010 07:01 PM |
BUG - ProFire 2626 with M-Powered | JVonD | Pro Tools M-Powered (Win) | 2 | 09-15-2010 05:00 PM |
help with profire 2626 in m-powered 8 | docterzaius | Pro Tools M-Powered (Win) | 1 | 07-27-2010 09:24 PM |
M-Powered with Profire 2626 as ADAT | steve3186 | Pro Tools M-Powered (Mac) | 11 | 05-02-2010 07:51 AM |
M-Powered 7.4 Cannot Find Profire 2626 | djad05 | Pro Tools M-Powered (Win) | 11 | 11-21-2008 09:34 AM |
