Old 01-24-2024, 05:29 PM
TrentWilliams TrentWilliams is offline
Default Avid Pro Limiter - Overs & True Peak Limiting
I've been using Pro Limiter for a long time, it's on all of my templates and is generally my go-to.
But every once in a while I'll print a mix where Pro Limiter can't catch all peaks no matter what I do, I'm starting to think it's not actually a true peak limiter?
If I throw ISL2 in its place, I get no overs no matter how hard a push it.
Anyone out there have any insight or guidance on this?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 01-24-2024, 08:53 PM
audiolex1 audiolex1 is offline
Default Re: Avid Pro Limiter - Overs & True Peak Limiting
I found that the LUFS numbers on dynamic parts are about .3 hotter LUFS than all other Measuring software.
I sent AVID all the info and proof of it but don't know if they ever fixed it, but sounds like no.
Nugen and Youlean are really good for measuring. I'm sure any limiter will work. I used the McDSP for a while.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 01-25-2024, 12:34 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Audio Engineering Society recommends we preserve the health of our hearing and suggest mastering music for streaming to:
-20 to -16 LUFS with transient peaks at about -9 or -8 dBFS.
Maxing up to 0.0 dBFS is old school, the wrong idea, and bad for ears, and there is a real understanding which has emerged that mixing at 0.0 dbFS and -14 LUFS is more likely to land one a loudness penalty.
Also, if a streaming service like Spotify or a distributor like DistroKid "maximizes" your audio, you will get a loudness reward if the peak gives headroom.
Therefore, if the loudness is -14 and that equals -14, why push everything so hot? Why not give headroom for the system? I think the "ears" do not really register much "impact" of micro and millisecond peaks in the -8 to 0.0 dBFS peak range, but they ARE more readily dangerous to electro-acoustic equipment.
The way -14 LUFS audio gets mastered to 0.0 dBFS peaks, there is not much dynamic room there to get it nicely mixed with other material in the future, like a soundtrack, or another "mixtape" or "album version."
If there was more headroom to begin with, "you can only go up from there."
My opinion is the 0.3 LUFS is meaningless if you turn down peaks to -9 dBFS, THEN get loudness where you like, without distortion. I bet it will sound better!
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 01-25-2024, 12:53 PM
JFreak's Avatar
JFreak JFreak is online now
Google for "intersample peaking" and you get a better idea about the phenomenon.
Janne
Old 01-25-2024, 01:02 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Talking post production / multichannel I agree that Pro Limiter doesn't catch precisely all peaks. It seems to be somehow frequency dependent.
However it's a way more transparent than Nugen ISL 2.
ISL 2 performs the worst on acoustic piano loud parts where you can hear the difference compare to Pro Limiter.
Having said that the ISL2 might be good for some subtle gluing effect on e.g loud explosion scenes.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 01-27-2024, 08:23 PM
This is all coming from a post-prod TVC workflow where I'm working to OP.59 (-24LKFS -2TP) for TV deliverables and -18LKFS -3TP for streaming deliverables.
So nowhere near music loudness.
My Pro Limiter rant comes from -3TP where i'm getting -2.8TP when setting it to -3.
Old 01-27-2024, 11:16 PM
henningaround henningaround is offline
I had the same problems with Elixir from FLUX.
I switched to Pro Limiter, but after a while to ISL2 because of the licensing model. I didn't want to keep up to date with Pro Tools Ultimate, which means I no longer use a Complete Plugin Bundle.
With ISL2, I set the threshold in all templates to -2.3 to make sure the -1 specs were met. Since then I've never had any problems, but I've also never tried to set ISL2 to the exact same threshold as in the specifications.
MGoorevich's comment about piano is interesting. I'll give that a try, but usually it's other elements like loud screams, bangs like gunshots and explosions etc that need to be caught by the limiter.
Old 01-28-2024, 10:08 AM
Eric Lambert's Avatar
One of the only plugins I've found that truly grab every ISP is FabFilter's ProL2. The Weiss maximizer and TC's MD4 are my go-to for the master fader but they occasionally let ISPs pop through.
Also, there's a free plugin from Avid called MasterMeter which is great for telling you when you have overs.
Old 01-28-2024, 11:14 AM
JFreak's Avatar
Originally Posted by Eric Lambert View Post
(...) TC's MD4 are my go-to for the master fader but they occasionally let ISPs pop through.
TC themselves say you need to put their brickwall limiter after.
Janne
HTML code is On
Flux:: Immersive Elixir Essential (Atmos True Peak Limiter) Megalobass AAX Plug-ins 0 12-03-2021 01:36 AM
Avid should bundle a True Peak limiter DSP Plugin ggegan Post - Surround - Video 16 05-21-2013 10:34 AM
Why is the limiter not limiting? World Spirit Pro Tools 10 12 03-31-2012 08:47 PM
Peak Limiting Question Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-15-2004 11:07 AM
Peak Limiting Somebody Pro Tools TDM Systems (Mac) 2 12-18-1999 12:07 AM
