Old 03-26-2023, 11:18 AM
pierrobass pierrobass is offline
Default File locations for uninstalling PlayCell?
Hi evreryone !
Do you guys know where those palette sounds are located ?
i'm trying to uninstall, but I can't find the exact folder location.
Old 03-26-2023, 12:25 PM
mattlange's Avatar
mattlange mattlange is offline
Default Re: playcell
Originally Posted by pierrobass View Post
Hi evreryone !
PlayCell has 2 folders.
The AAX presets can be found in User/Documents/Pro Tools/Plugin Setting/PlayCell
The sample content can be found in MacHD/Library/Application Support/Avid/PlayCell
Old 11-06-2023, 02:45 PM
briaboy briaboy is offline
Default Re: File locations for uninstalling PlayCell?
Hi - I just installed Avid Link (to use Sonic Drop's Purrcell). The files contained within the various PurrCell folders are .tfx How do I use these within Pro Tools? They appear in PlayCell, but won't open in Pro Tools PlayCell plugin for some reason, even though they are visible in the installed files on Pro Tools/pluginSettings/PlayCell/PurrCell. See attached screenshot. Thank you!
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
Old 11-06-2023, 10:07 PM
jzenterous26's Avatar
jzenterous26 jzenterous26 is offline
Palette sounds are usually in the program's installation folder. Check there, and you should find them.
Old 11-07-2023, 09:21 AM
As you can see (attached screenshots), the Factory files and the PurrCell files are here. But, the Factory files open just fine in Pro Tools/PlayCell, the PurrCell files don't - "missing content".....
"PlayCell Palette install failed" trying to install PlayCell 2023.3 Dizzi45Z Virtual Instruments 3 03-28-2023 12:40 PM
File Locations frones jones IX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-20-2004 11:56 AM
Audio File Locations & Templates dpdemo Pro Tools TDM Systems (Win) 3 11-28-2001 04:34 PM
File Locations JB3 Pro Tools TDM Systems (Mac) 5 11-03-2000 12:19 AM
