Old 04-03-2022, 12:30 AM
ramonetl ramonetl is offline
Default Mystery Fader Strip keeps popping up
Hi all, I dont know if I am doing something silly but I have a new mac and have been moving everything over from my old mac. This means all clean installs of PT, plugins, UAD software etc. I then copied over some projects and opened them up but I keep getting this fader meter popping up non stop and I cant make it go away. it doesnt seem to have focus on any particular track and even if I close the mix and edit windows it keeps popping it up (or minimizing). I tried making a brand new project and then started redoing stuff and it showed up again. I am scratching my head trying to figure out if i have something selected in preferences? I think it may be related to toontrack but i just dont have any damn idea. It reminds me of the fader that pops up when you create a fx send. Any thoughts are greatly appreciated. I am migrating from a trash can pro to a mac studio. Both OS versions are identical and I have never seen this particular thing happen with any other os including the same on the mac pro. Thanks. Peter
File Type: jpg Screen Shot 2022-04-02 at 6.23.12 PM.jpg (42.5 KB, 0 views)
File Type: jpg Screen Shot 2022-04-02 at 6.23.29 PM.jpg (34.5 KB, 0 views)
Old 04-04-2022, 07:25 AM
Default Re: Mystery Fader Strip keeps popping up
Are you using EuCon?
Scott Gatteño
Old 04-04-2022, 10:53 PM
I am. I double checked my settings but when this started i had not yet enabled the eucon on PT yet.
Old 04-05-2022, 06:33 AM
Southsidemusic's Avatar
This is just me and how we do it here but we never ”copy over” anythyas it tends to break things sooner or later so IMHO and i knlwit’s time consuming but we fe-install everything when we swap Apple mac.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-05-2022, 07:56 AM
BScout BScout is offline
More importantly, if you disable eucon in Pro Tools, does it go away?
This looks like the eucontrol settings on the General tab for "open windows on workstation" has pan included (which is on that same fader strip)
The reason it may not seem like it is following a track is because the "attention most recently clicked DAW area" in Eucontrol choices. So even though you might not have selected a track, if you click in the Edit window on that track's area in the work area, Eucontrol will focus on that without the track being selected in Pro Tools.
Old 04-05-2022, 12:56 PM
Thanks I think you may be on to something. I dont really recall what I had setup exactly on my other mac and I already flattened it to sell. here is a screenshot of my settings. Do you have any recommendations on what to modify? I did turn off the eucon in PT and closed it and then closed the strip and it did not pop back on even after I re-enabled eucontrol. I need to definately read into the settings a lot more in the eucontrol manual. I appreciate your time it was really helpful. Thanks Peter
File Type: jpg Screen Shot 2022-04-05 at 12.51.34 PM.jpg (43.8 KB, 0 views)
Old 04-05-2022, 12:57 PM
Sorry maybe I was not clear i only copied over the project files. Everything was a clean install from Protools to all my UAD and plugins software. I didnt want to bring any unknowns from my mac that could cause me grief.
Old 04-05-2022, 01:20 PM
First thing that will stop this is:
change "Open windows on workstation when editing:"
(left column, lowest drop down box)
to an option without "Pan". It can't include Pan as pan is what's causing that fader to pop-up.
If you want the track that's in focus only to be the track you have clicked the track name (or clicked on a control on that track) for Eucontrol, uncheck "Edit window" in the "Attention most recently clicked DAW area"
Full Channel Strip for Focus Fader skilletaudio Avid S4/S6 4 10-16-2019 02:51 PM
Opening Send Fader Strip TerryBarnett Avid S1, S3, Dock and Control App 0 12-21-2017 08:50 AM
002 Problem with lights, scribble strip and one fader! jjtguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-13-2011 08:04 AM
Channel Strip on Stereo Master Fader stevemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2002 08:25 PM
Channel Strip and Master Fader fifty8th1 Tips & Tricks 5 06-07-2001 02:56 PM
