Any way to remove the white bar at the top of the movie window?
As stated in the title... previous versions of protools would make this bar disappear if you selected "fit to screen", but it seems to have creeped back into PT8. Maybe it's LE related... I'm using an LE system controlled via Satellite for video playback. Would suck if I had to buy another HD system just to get rid of the white line....
It's really unprofessional looking to have it projected onto a big screen with that darned thing up there. Maybe there's a preference somewhere that I'm missing? |
Re: Any way to remove the white bar at the top of the movie window?
Hi Jamey,
More likely it is the QT's aspect ratio does not match that of the monitor. This is what happens with a mismatch even in 7.3.1 HD.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Its not much, but enough to notice. I use Vizios with overscan adjustments. |
Me too - I get the white bar and my Quicktime is sized to 1280 x 720... Oh and my display is sized to 1280 x 720.
Bah!! |
Could one of you guys post a screenshot of the "white bar" such that we can know exactly what you are referring to?
http://dl.getdropbox.com/u/1688287/Whitebar_QT.png
It's the bar across the top - with the little red x in the left corner... Picture is nothing exciting |
...a REAL burn-in problem when playing 1920x1080 HD files on plasma via DVI.
pb |
Thank you for the responses! I took Tom's input and started messing around with outputting different resolution movies to see if I could resolve the issue, but based on many hours of tests, I have come to the conclusion that he is wrong. This is not a resolution issue at all. Sorry Tom, but thanks for the thought.
Here's an image from my studio. You can probably see how much of a disturbance that little strip of white is to the entire viewing experience. http://dramaticmusic.com/images/QTLine.jpg |
Jamey,
I meant the resolution of the monitor. It has to match the ratio of the QT. Or, you have to Zoom. On my system, I have 2 monitors, one NTSC CRT and one HD Plasma. This is the 2 desktop, dual DVI deal. My CRT I set the 2nd monitor to 720x480. Once I "Fit Screen" there is NO white bar on any movie, UNLESS it does not match the aspect. Then I have a white bar. (This is out the Apple DVI-->Video adapter). The Plasma 2nd monitor is 1280x1024 and there is NO white bar on most movies, unless the aspect does not match. Even NTSC 4x3 movies even go full screen, when I "Fit Screen". In SOME cases, I have to switch the Plasma to "Zoom". For instance, right now, I am working on a film that is 24fps, and it does not "fit" the CRT, but "fits" the plasma. So, maybe try futzing with your display aspect.
remove a movie from a session | SupreGlu | Post - Surround - Video | 15 | 02-16-2014 12:35 PM |
How do you remove a movie from a session? | daeron80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-07-2011 11:46 AM |
How to remove the midi window in PT 8? | Dopamine | Pro Tools TDM Systems (Mac) | 1 | 01-20-2009 09:43 AM |
Remove volune line in edit window? | Tom Harmon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-08-2004 12:20 PM |
Quicktime movie window white! | Gr0und_Zer0 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-02-2003 01:35 AM |
