Delay when recording vocals...
MBox2
ProTools LE 7.0 WinXP AMD Athlon 64 1.5 Gig of RAM When recording vocals I have this terrible delay through the MBox if the MIX knob is anywhere but fully left. But then I can't hear anything else if it is. I've tried setting the PLAYBACK ENGINE options but to no avail. If I lower the number of voices to 128 samples the echo is a little tighter but then I get an error saying my system is running out of memory and I should remove some plugins from the mix. If I raise the number of voices the delay gets longer. Anyone have a fix for this? I really need to record vocals and this is throwing them way off. |
Re: Delay when recording vocals...
Mute the channel in Protools you are recording to.
http://www.oneearthproductions.net |
DOH!
Well, yeah, I guess I could just do that. Thanks. But is there anything I can do withing PT to fix it? I would think it's a latency problem, but I can't find anything relating to latency in there. |
this aint within. If you got an external mixer lying around. I use it to get rid of latency when recording. If you don't know how to set up, it aint for you.
If you had a 001 or 002 there would be a low latency monitoring option within PT itself.
Well, I'll give ya credit for at least trying to help, casperfun, but then ya killed it with that lame comment at the end. If ya don't mind, I'll be the judge on what is or isn't for me. Not everyone on here has been using ProTools forever, you know? Be constructive, not destructive. PEACE |
If you check "low latency monitoring" that should clear up much of the problem. You may still hear a slight offset, but it shouldn't be enough to prevent you from working. The low latency option is found at the bottom of the Options menu on Pro Tools 7 LE.
Edit: I tried to attach a screenshot but the "attach file" feature has been turned off in these forums. |
Here's a good read from Sound On Sound regarding latency in Pro Tools LE:
http://www.soundonsound.com/sos/jun0...kshop_0606.htm |
DJTMS, that is how the USB units function, it is not a "problem" that can be fixed or a setting that you are missing, and Mark (Aussie169) has given you the proper advice.
Then perhaps some of the other options outlined in the Sound on Sound article may work for him? I'm not familiar enough with the various versions of MBox to know for certain.
I did apparently miss Aussie169's post. Mea Culpa, or as the hipster's say: "my bad". |
i have a delay in my vocals while recording. | kinglewis1 | General Discussion | 3 | 07-21-2008 10:00 PM |
Problem recording vocals!!!Help!!!Delay!! | dmt2828 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-11-2007 12:14 PM |
PlayBack Delay In Vocals When Recording!!Help!!! | Las Philosophy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-03-2007 06:36 AM |
Delay while Recording vocals | zafar1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-22-2006 08:47 AM |
recording delay on vocals | MidnightFlyer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-01-2005 04:14 PM |
