Old 12-24-2023, 11:41 AM
paul_g's Avatar
paul_g paul_g is offline
Default bouncing sometimes excludes v-instruments
(I won't use the word bug...) rather an issue, where when I bounce a session to mp3, sometimes it excludes my virtual instruments, and sometimes it doesn't.
I did trash prefs earlier in the week, but that was due to a EuCon issue, which I resolved, I haven't trashed prefs again yet...
Sometimes if I select another track, then come back to the master track and try to bounce again, it's resolved. Sometimes it takes three tries before it gets everything. I may try trashing prefs again, and if persists I'll open a case. Just posting here incase anyone else noticed the issue.
I'm on 2023.12
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 12-24-2023, 12:37 PM
massivekerry's Avatar
massivekerry massivekerry is online now
Default Re: bouncing sometimes excludes v-instruments
This is not a definitive answer, but more a speculative and anecdotal one. I have noticed that some VIs that I own (especially ones that use heavy multi-sampled sources) sometimes do not like to play back during offline rendering (be it Bounce, Commit, or Freeze), especially if I am pushing my CPU or have a lot of latency/delay compensation in the session. I have attributed this to the specific instruments and not to PT, and will often do a real-time print to an Audio Track of the finicky instrument so that it is not an issue when I Bounce mixes and stems.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 12-24-2023, 02:08 PM
paul_g's Avatar
Thanks Kerry, oddly it's xpand, a PT plug, so I'd hope they could handle that.
I'm barely touching CPU and memory... Thanks for the idea of a realtime bounce of the VI. THat's not a bad idea. Sadly I forgot to mention it's not grabbing some of the busses w/ delay & verb either. So it's a weird thing.
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Old 12-24-2023, 04:50 PM
Paul
It's so easy to bounce the wrong source in Pro Tools, all of us have made that mistake (many times, sigh). You might have carefully checked this already, but I have to ask... check carefully what source you are bouncing in the bounce dialog box, make sure that is the physical output you are monitoring, which is presumably what you want here. Don't be tricked by similar looking names or any mess in Setup>IO etc. That's sure my first guess if you are missing multiple things... esp. just missing the VI by itself
Old 12-26-2023, 08:46 PM
paul_g's Avatar
Paul
Thanks for this Darryl. The thing is, I'll bounce, then just tweak a compressor or a level, and renounce, and missing audio. I'll click off the selected Master track, on something else, click back and bounce again and it's fine. No settings are getting changed. It literally happens between checking a file and tweaking a level or a compressor or something.
I can do this 10 times and reproduce it 5 times randomly. I'll trash prefs.... reboot and try again.
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Moving installed virtual instruments like Air instruments and synthcell that came wit Alberto87 Virtual Instruments 1 12-02-2022 04:42 PM
FS: McDSP, Native Instruments Absynth 5, iZotope RX, Air Instruments antonis Buy & Sell 0 03-08-2018 05:25 AM
Bouncing in session first vs. bouncing straight to disk... WATYF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-07-2007 03:17 PM
Bouncing instruments and delay compensation? pukeuv Tips & Tricks 16 09-30-2007 09:28 AM
Problems Bouncing Virtual Instruments Into Audio ANCO Tips & Tricks 1 01-28-2006 07:55 AM
