Using Latch automation
When I use the latch automation, I can set a point, move down the clip and set another point and the automation has reset. I am not sure that I fully understand this process, or maybe there is something occurring that I need to be aware of.
Suggestions? I run PT 10.3.7 on an iMac running Lion (not Mtn. Lion). Thanks! |
Re: Using Latch automation
Latch automation is a mode where touched knobs and faders will keep writing automation until you stop playback. HD and CPT systems allows you to prime as many parameters as you like prior to playback, and they will keep writing automation until you stop.
Sounds to me like you're manually editing automation playlists?
Latch (as with the other modes) is for the writing of realtime automation when the transport is in play. (going to disregard Latch Prime in Stop and Preview mode for now) http://www.youtube.com/watch?v=IzFcz5pucus Start with a basic tutorial like this one. I have no idea if it's any good, didn't watch it, just found it via a search. |
Latch automation and multi-mono plugins | Stig Eliassen | ICON & C|24 | 14 | 12-26-2010 04:15 PM |
Can't create automation using write/latch feature | Jambroch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-30-2008 02:50 PM |
Automation over writing problems in touch latch using a d-co | Brandonx1 | Post - Surround - Video | 0 | 04-15-2007 11:16 AM |
7.2 automation offline Latch prime bug | Steve MacMillan | Pro Tools TDM Systems (Mac) | 2 | 08-22-2006 02:06 PM |
6.9 Default to Auto Latch after Write Automation.. | a2zproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-20-2006 12:10 AM |
