Have you seen this Trim Automation bug?
With every PT HD update I check to see if this bug is fixed as I've been dealing with it since Pro Tools 9. Here's the scenario:
You have a Trim plug-in automated and make some changes in level. In the pics attached, I start at -12 for the whole clip. Then I make an adjustment in the middle of the clip 6dB lower, so it reads -18 in the middle section. Then I want to lower the overall Trim volume by a certain (delta) amount, and of course I want the relative changes to stay in tact. If I lower it by say, -8dB, the new trim level should be -20, and -26 in the middle. But take a look at Pics 4 and 5: The result is - 21.6 and -43.6! This is the typical behavior - it just gets more extreme with larger changes. |
Re: Have you seen this Trim Automation bug?
I can confirm that behavior here, both with Native and DSP version.
Same on Win : -21,4 and -43,0.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thank you both. Now I need to figure out how to send Avid a bug report.
Yay we have trim plugin automation on non Hd | boabyd23 | Pro Tools 9 | 19 | 11-12-2010 10:11 AM |
No Trim Automation in PT8 M-Powered? | solardarkroom | Pro Tools M-Powered (Mac) | 0 | 11-05-2010 02:02 PM |
Trim automation above plus 12? | andydadd | Pro Tools TDM Systems (Mac) | 1 | 06-07-2007 08:56 PM |
trim automation | booboocakesjones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-10-2003 01:13 PM |
Trim automation | cachemira | Tips & Tricks | 11 | 07-03-2003 03:14 AM |
