iZotope Vinyl weirdness
I love this plug... but I put it on the Master fader with a bit of mechanical and electrical noise as a background... now I put my master fader all the way down and the noises are still there... where am I wrong ?
Also if you click on at least three of the four little holes on the corners the plug opens a new (secret...) window...
http://www.stevegalante.com |
Re: iZotope Vinyl weirdness
Inserts on master faders are post fader
Ooopss... you're right...
Hahahaha, brilliant! I've been working with this plugin for many years and never found this one.
Now's a good time to get in the habit of using a mixbus/ aux before the master fader for the above reason! Also good if you want to RCD recod to disk instead of bouncing! Many advantages using a mixbus for your overall processing and keep the master fader for metering! This also helps if you have other stuff routed into your PT session like iTunes etc which you don't want processed yada yada! Chris
What you mean by iTunes routed into PT session ???
if you have a dedicated aux ( i call mine "mix") with your processing on it, and then route that to your master, and do a/b' s vs. your reference (with it bussed to the master) you'll be apples and apples... (plus no drama with the pre/post issues on fades.) e
ihatetyping |
well, you can do that, too...
in the above example you can either import an audio file into tools, say, from a cd. or, you can connect your optical digital out jack into your optical in on your interface, switch apple sys prefs to "digital out" on the sound ouput panel, and then route myspace, itunes, or your naughty vids right in. e e.p.s. Quote:
ihatetyping |
iZotope Vinyl AAX? | Dizzi45Z | Pro Tools 11 | 36 | 02-02-2016 12:29 AM |
Izotope Vinyl issue | dacoma09 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-30-2013 07:06 PM |
Izotope vinyl | adamjay | Post - Surround - Video | 1 | 10-06-2010 01:09 AM |
iZotope Vinyl ??? | RokVox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 08-17-2006 08:52 PM |
iZotope Vinyl plugin | jvox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-26-2004 12:05 PM |
