Old 01-18-2011, 12:20 PM
BtotheZ26 BtotheZ26 is offline
Default Questions about Removing PT/Then re installing
Can i just remove PT and re install it without having to re install all the other stuff like mooger/bundlepack/structure free?
Will it still be registered?
Old 01-18-2011, 01:24 PM
Default Re: Questions about Removing PT/Then re installing
Plugins usually remain in place. You will likely need to type/paste in the authorization code again(PT9 now uses iLok so it has no code).
Old 01-18-2011, 01:35 PM
Ok awesome...is there any place where the authorization code would be? I still have the registration card with the upc ...is that the code? if not, where can i find it?
Old 01-18-2011, 01:46 PM
I have an ilok key registered...so should that be all i need?
Old 01-18-2011, 04:40 PM
What version of Pro Tools? If its PT9, then the iLok should do it. If its 8 or older, you need the authorization code. Pre 8 usually had it on the inside cover of the Getting Started Guide. PT8 usually came with a card with a registration code. Once you registered, Digidesign/Avid emailed the code(which would start with something like "DIGI0800 xxxxxxx". Check your MyAvid account as it should be listed there. I suggest(assuming you find it), writing it down in at least 3 places.
installing questions pinnacle macOS 28 03-24-2012 01:00 PM
Question about installing TL Space Native DVD / Removing Trial Version jasonfarnham Virtual Instruments 4 07-31-2011 02:38 PM
cpl questions about installing ilok skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-07-2005 07:15 AM
Installing hard drive questions Brian Mastalski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 01-17-2003 11:03 PM
still having oasys problems - questions for group re: removing digi Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-08-2002 04:22 AM
