Old 04-21-2004, 01:13 AM
Johnny916 Johnny916 is offline
Default Recording vocals with Pro Tools, MIC GAIN>
Hi, Can somebody tell me how high my gain should be when recording vocals?
I'm not sure how to explain this but when I look at the data on vocal audio tracks it doesn't look very THICK..? Should the vocal data range be as close to the top and bottom of my audio tracks as possible??
Please help!
Never underestimate the predictability of stupidity!
Old 04-21-2004, 02:32 AM
AfricanCaneKing AfricanCaneKing is offline
Default Re: Recording vocals with Pro Tools, MIC GAIN>
its really all relative, but i try to mke sure i get my vocals recorded as loud as possible with out clipping. i watch the mbox and make sure as my vocalist performs the peak light doesn't light up, or if it does it lights up rarely. also use your ears, you cant mix your music visually its better to listen than watch peak meters and wave forms
2.0GHz Intel Core 2 Duo + 2GB RAM
el-cheapo compusa generic firewire 80GB
OSx 10.4.10, PTLE 7 (latest update)
Old 04-21-2004, 05:46 AM
GapeOne GapeOne is offline
I usually try keep mine at around 12 o'clock when I record myself, but when my guys are in the studio recording it tends to be in the 9 o'clock setting as they have a much stronger projection.
As for your vocal data not being too thick, try Normalizing your vocal data. In your audio suite there is a Normalize plugin that you can use to bring all of your vocal peaks to 0db (Not exactly sure of the proper wording either, but this boosts your vocals AKA makes the vocal data thicker).
Good luck!
- GAPE
www.myspace.com/soulskool
Old 04-21-2004, 06:39 AM
where02190 where02190 is offline
For an 001 and M-box, nominal (average) levels should be -18dbfs, for the 002/002R -18dbfs. This applies to anything you're recording. This allows adequate headroom for transient peaks while achieving best possible audio quality.
Check out the Pluggo PeakMe for a decent, accurate meter plugin.
Recording Vocals With Pro Tools BrianCeballo macOS 6 11-03-2014 09:51 PM
Vocals Cutting out while recording in Pro Tools Le 8 Endyga Pro Tools M-Powered (Mac) 0 03-11-2011 05:41 PM
Having a problem in Pro Tools when recording vocals musiclovin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-09-2010 09:20 PM
Problem with recording vocals in Pro Tools 8 Abdul Aziz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-02-2009 10:05 PM
Pro Tools LE 7 Recording Vocals Problems.. Help!! dmt2828 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-29-2007 12:45 PM
