Old 11-18-2020, 12:49 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Default Recording from track to track or aux to track not aligned
So, if you assign a track out to another track and record enable (printing the plugins from the first track) the two do not line up. In my testing the second (processed) track is around 300 samples delayed.
I experience the same if I use an aux set as output to another track and record on that second track. Same offset. What is the cause of this? Is it resolved in later PT versions?
Currently using 12.8.1.
Thanks!
Old 11-18-2020, 08:11 AM
Default Re: Recording from track to track or aux to track not aligned
Is Delay Compensation enabled? What numbers are you seeing regarding latency on the source track(s)? Could it be a plugin's latency is not being read correctly(which would cause incorrect compensation) or does the delay window show red(meaning its out of the range of compensation)? Assuming Delay Compensation is enabled, I would use the original audio as a reference and nudge(or SPOT) the new audio into the correct position.
What is the reason for this routing(IOW, is there a better way to reach the same goal)? What about using Track Commit(I can't remember if 12.8.1 had that feature)
Old 11-19-2020, 12:52 AM
Commit does not have offset. Track delay is only 4 samples. I'll try toggling delay comp.
Old 11-19-2020, 12:58 AM
No change.
Instrument track active while recording audio track Soundy Pro Tools | Intro Discussion 2 03-29-2018 05:06 AM
Wav audio bed track recording into vocal track! KL127 Pro Tools 10 2 02-03-2015 08:45 AM
PT11 2nd track automatically recording 1st track's audio problem KungFuRooster Pro Tools 11 9 08-18-2013 10:44 PM
Track Names Aligned to the Left josh_hopwood Tips & Tricks 2 04-30-2010 05:49 PM
random entire midi track pitch changes after recording track bitterkitten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2010 07:23 PM
