setting start and end points for tracks?
I've bouncing off the walls trying to figure this out. any help this one is appreciated. thanks in advance.
MacPro Quad Xeon 64 Tiger 10.4.9/ 2.66 Ghz / 32GB RAM / ProTools LE 7.3 /MBox2/ T-Racks24 / Motif 6 / ASR10 / Rokit 8's / Audio-Technica mic / AKG C3000 mic GMP |
Re: setting start and end points for tracks?
setting start and end points for tracks? Why?
Are you trying to set your Bounce to disk start and stop? If so, just drag a selection in the Timeline. The blue down arrow is start the blue up arrow is stop. You can grab the arrows to fine tune the selection, too.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
yes, that's exactly what I'm trying to do. thanks for the tip, I'll try it now.
Also, when I set these points, I want to hear it "loop" so I can do some critical listening.
In loop playback, it will follow the selection in the timeline..
You might want to look up Dynamic Transport in the manual.. There is also a Digi Accelerated video that shows it in action. It is handy for doing edits in a looped region...
Try selecting the space you want, and creatingia section marker. Then every time you chose that marker, the selection you want is highligted again.
Also, try avoiding bouncing... bouncing and printing to track are not the same in ProTools (one example being that Bouncing thins out automation data). When you print to track, what you hear is what you get, no smoke and mirrors. |
Setting Loop Points Within a Sample | weezerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-09-2009 05:08 PM |
Setting In and Out Points | John Fishback | Pro Tools TDM Systems (Mac) | 7 | 12-17-2006 09:01 AM |
help with setting loop points | Equality 7-2521 | Tips & Tricks | 2 | 07-17-2005 11:40 PM |
Setting beginning and end points | FullFreq | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-29-2004 01:49 PM |
Playback start points | dBHEAD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-03-2000 07:35 AM |
