Old 11-14-2015, 10:30 PM
dadavis2307's Avatar
dadavis2307 dadavis2307 is offline
Default Unable to Locate Hardware
I've installed and updated everything.
Uninstalled, unplugged, reinstalled and re plugged.
I'm getting the message;
"Unable to Locate M-Audio Hardware. Make sure your hardware is plugged in and turned on."
I've seen a few solutions for other versions of PT's and other OS, but none of them have led me in the right direction.
I'm considering calling AVID directly, but they no longer offer support for products this old.
Help?
Old 11-14-2015, 10:33 PM
Default Re: Unable to Locate Hardware
My signature hadn't updated yet, so here's my system info.
Dave
Windows 7 Ultimate
Intel I7 2.93 GHz
8 GB of RAM
64-bit OS
PT 8 M-Powered
M-Audio Fast Track Solo
Old 11-15-2015, 09:05 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
If you haven't tried it already, go to control panel, and select "sound". Make sure that the Fast Track Solo is not selected as the Windows default sound device under both the Recording and Playback tabs. If it is, Windows grabs the Fast Track for itself denying PT access. Remember, system sounds and audio from the internet will not play through your Fast Track with this configuration.
I see that you are using 8MP. Have you installed the free 8.05 update for Win7?
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 11-15-2015, 09:15 AM
Southsidemusic's Avatar
If that doesn't work hold down the "N" key when launching PT and choose your interface when the window pops up.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-15-2015, 08:58 PM
Thank you for replying!
Wizzoboy
I went through the control panel and made sure the fast track was not the default device. On both tabs, but nothing changed. I was waiting until I updated, but I figure nothing could make things worse at this point, so I Downloaded the update. But when I tried the updater it says "Cannot locate a valid Pro Tool's installation on my system."
Southsidemusic
I wasn't able to get any menu to open up during the loading of PT's. The program makes it to DAE loaded and cuts out unable to locate the device. Might it be after that point?
Dave
Windows 7 Ultimate
Intel I7 2.93 GHz
8 GB of RAM
64-bit OS
PT 8 M-Powered
Old 11-16-2015, 05:38 AM
Wizzoboy's Avatar
That would seem to indicate an installation problem. On what drive have you installed PT?
I used to use PT8 MP under Win 7 Ultimate with no problems so there is definitely something amiss.
Old 11-16-2015, 05:41 AM
Your interface is USB right? Check Windows Control Panel and make sure your USB ports are not set to power down. Windows has a nasty thing of defaulting the ports to power down to save power which is a holdover from laptop usage to save battery power. Also make sure your interface is plugged into the same one that it was connected to when you installed it and drivers the first time. Another nasty Windows habit in that it may not recognize a peripheral if you move it to another port (the 'universal' in USB isn't always so).
Old 07-03-2016, 09:57 AM
VisionsMusicGroup VisionsMusicGroup is offline
I do not post here much, but musicman691, you are my hero. I have a Mackie DL32R that was working brilliantly, then "all of a sudden" one day PT refused to see it on start up. I would have to pull the USB out and put it back in to re-awaken the USB. I never even considered the Windows power-down USB as a cause. THANK YOU!
Soon as I disabled power down of the USB for this particular USB Hub, the Mackie has no trouble being discovered.
I am posting because so many others just ask questions and never bother to come back to offer the answers :) Hopefully this helps someone else who's been scratching their head for months.
Jc
iMac (Retina 5K, 27-inch, Late 2015)/32GB RAM/MacOS 12.6/PT2022.9 - Hardware: Mackie DL32R, MOTU Express 128, S3+Dock
Old 07-03-2016, 12:00 PM
Jc
Glad I could help and that the USB power savings was the problem. Not many people think of that but it's one of those things I fell prey to a long time ago when I ran a Windows system.
And as to posting back that is much appreciated. It lets us know if what we posted helped or not. And if not it also lets us know we need to think of other things. Helping each other is the way to go.
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 09:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
unable to locate M-Audio hardware. Make sure your hardware is connected and turned on joskraus Pro Tools M-Powered (Win) 13 05-13-2009 09:05 AM
