Old 06-06-2010, 08:52 AM
User999 User999 is offline
Default Manually installing Pro Tools
Hey there,
As my Mac's CD/DVD drive is broken I have had to copy the Pro Tools disk onto another computer and then transfer the folder to my Mac via hardrive...which I have done.
Can someone please tell me how to manually install Pro Tools.
Many many many thanks!!
System spec:
Mac OS X - Version 10.4.8
Processor 2.16Ghz Intel Core 2 Dui
Memory 3GB 667 MHz DDR2 SDRAM
Old 06-06-2010, 08:55 AM
Default Re: Manually installing Pro Tools
Sorry I should have also mentioned. I am trying to install Pro Tools 7.3 for a 003r
Old 06-06-2010, 09:27 AM
anyone? Please!
Old 06-06-2010, 10:05 AM
Holly73 Holly73 is offline
In which format did you store it on your harddrive? If it is a .dmg, just run the installer like you would do with any other program. If it is an .iso, just mount it using Disk Utility and install it from there.
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 06-06-2010, 11:30 AM
Hey Holly73, Thanks for replying.
What I have on my screen is a folder in which contains 8 other folders, named such as 'additional files', 'drivers' 'Pro Tools LE installer' etc...and within pro tools LE installer folder there are 9 icons named such as _setup.dll, data1.cab etc etc
I'm thinking I may have to either get my dvd drive repaired or perhaps buy a external hard drive with dvd slot...???
Old 06-06-2010, 11:35 AM
Perhaps i've done something wrong here because I have a folder named Pro Tools in which there are multiple folders named such as - 'pro tools le installer' 'Drivers' 'Command8 installer'. In the 'pro tools le installer' folder there are 9 icons with names such as _setup.dll data1.cab setup.exe
I'm thinking I either need to get my dvd drive repaired on my Mac or an external hard drive with a dvd slot..
Old 06-06-2010, 02:23 PM
Craig F Craig F is offline
There should be a Install Pro Tools LE.mpkg file that you double click and away you go.
Is it posable you missed copying it?
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 06-06-2010, 03:25 PM
soundboy35 soundboy35 is offline
Sounds like you have PC files when you say file types of: .exe, .dll,.cab, etc
If it really is a Mac version, you would probably be able to just burn the Application file to a CD, copy it to the other Mac/Application Files and fire it up. I have to say it's probably not going to happen on a PC, as they have so many extra files as compared to Macs. Or as Craig says, look for a .mpkg file and copy that over to install from. Good luck
Mac Pro Dual 3GHz
10.8.5, PT10.3.9
MacBook Pro 15in, 2.3gHz,i7 Quad Core
10.12.6, PT12.8.
How to manually apply swing jlnelson19 Pro Tools 9 1 02-16-2013 07:48 PM
How to manually authenticate plug-ins for Pro Tools LE Manish Wayz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-09-2008 04:34 PM
A way to manually input pan value? jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-09-2006 06:05 PM
Manually Re-Linking Files autopilot Pro Tools TDM Systems (Mac) 1 04-25-2005 05:13 AM
DigiBase: Manually relinking help Dan Pinder Tips & Tricks 2 09-14-2003 03:44 PM
