Pro Tools 2020.5 not launching
Hello - running a Mac Pro Mac OS 10.13.6. Just downloaded and re-installed 2020.5 again after trashing Pro Tools preference folder. Running into the same issue every single time. Launch gets through splash pane and begins loading plugins. It crashed every time it reached Native Instrument's "Massive" plugin. Is there some way for me to bypass this one plugin? If not, is there a way to open Pro Tools without scanning plugins? Thanks!
Re: Pro Tools 2020.5 not launching
Are your plugins up to date? Compatible with 2020.5 and the macOS version?
I would have looked at the plugin first, checked its version and try a clean reinstall of the plugin if it's a supported version. All before messing at all with Pro Tools. Pete Gate's PT Prefs, besides being the best way to trash prefs will also list all versions of plugins installed (that feature got added back recently). For any misbehaving plugins you can move the corresponding .aaxplugin file out of the plugin folder ('/Library/Application Support/Avid/Audio/Plug-Ins') put it anywhere else like 'Plug-Ins (Unused)'. Then trash prefs with PT Prefs. If you see strangeness, try removing the previous plugin that loaded before the one that looks like it caused problems, trash prefs. Still stuck move all .aaxplugin files out of the folder, trash prefs and try that. (Pro Tools will auto magically put back it's base plugins). Last edited by Darryl Ramm; 07-11-2020 at 10:49 PM. |
Yes - all plugins are up-to-date. Also run Digital Performer and Logic - no problems at all. I just update Pro Tools from 2020.3 to 2020.5 and this is what happened. And like I said, it crashes each and every time when it reaches NI's Massive plugin. I will try removing it and re-starting to see if that helps. Thanks.
All Darryl said and also if you have a older Mac Pro (pre 2013) cheesegrater you cant run Massive X as it needs to be run on a compatible Mac Pro i.e trashcan and or the new 2019 Mac Pros so so match f you are using the new updated Massive from NI you have to remove it from the folder Darryl posted.
Hi Darryl,
How do you trash PT Prefs? Quote:
Follow the instructions under "Help us help you" up the top of each DUC web page.
Or easier use Pete Gates' PT Prefs utility. http://petegates.com/pg-pt-prefs.html Anybody using Pro Tools should be familiar with all the optimization and troubleshooting stuff under "Help us help you", so give that a read at some point. Are you running Massive X... Christopher and Jack have much more specific points there. |
Hi all - I did what Darryl suggested and ... YES! Pro Tools finally got past Massive - I removed Massive from the plug-ins folder - that was the first culprit. The next problem was SampleTank 3 so I removed that from the plug-in folder. The next issue (which I am currently working on) are some of my Izotope plug-ins. First the launch stalled on IZRX7Declipper. I re-launched and it stalled on IZRX7Deplosive. Since it got a little further along without me removing anything, I decided to launch PT yet again. This time it crashed on IZRX7Humremoval. I'm now on my 9th or 10th re-launch today. I do have a huge number of plug-ins. Another issue has now reared up - hanging on WaveShell2-AAX 11.0, specifically 11.052 Prefs. I'm gonna keep going until I get this application open.
This seems to me to be a fix that Avid should list. When I did a search for help, nothing from Avid came up. And I searched at least 10 different ways using as many possible terms I could think of. I thought that it was Massive that was my ONLY issue - it stopped there each and every time which is why I mentioned it. However, to be clear, there were very few (if any) fixes from Avid returned by my search. Avid should have easy and clear answers to issues like this. Anyway, my sincere thanks to Darryl for jumping in here to help! |
Yes - OP is using a Mid 2012 Mac Pro
Question: How did you get High Sierra on your computer? Was it as an in-situ where you installed over the top of an existing OSX install? That's not a good thing even though it's the Apple Way. Do a clean install of High Sierra and then reinstall everything from scratch. Do NOT use Migration Assassin. |
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? | derrickhou | macOS | 4 | 07-26-2020 07:46 AM |
Avid Control App Rollback (2020.5 to 2020.3) | budster | Avid S1, S3, Dock and Control App | 2 | 06-09-2020 11:01 AM |
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
New Avid Link 2020.1 - launched today 1/16/2020 | marianna | Licensing & Accounts | 8 | 01-16-2020 11:43 PM |
