> Midi per note output mapping
First a bit of a definition in case the subject is not clear. . . Midi per note output mapping (output Port, Channel, Note #) - The ability to map each different midi note #s on a Midi track to specific outputs, midi channels and/or notes. For instance a midi drum track could have C1 mapped to two or three different kick drum samples (snap, close, room), from 3 different Virtual instruments, while snare note D1 could be mapped to yet another VI. This is extremely useful because midi drums are much easier to edit when all notes are on one track, and if you can map these notes to any sampling devices then the sky is the limit for accessing sounds with ease.
Cubase had something like this in the first version, and probably still does. I believe it was called Drum Tracks and was something you could enable on a midi track-by-track basis, and you could save/call in map presets, at least that is how I remember it, but it has been about 9 years since I touched Cubase. I have asked Digi for this feature as long as 8 years ago, and a few times since then. I am completing some jingle work right now and could really use the feature again. Anyone know if Digi has this midi feature on the horizon?
...for system configuration info see my profile (Click on member name) |
Re: > Midi per note output mapping
PT Output constant middle C MIDI note | txshonk | Pro Tools 10 | 3 | 11-25-2012 03:27 PM |
What is that A 1-2 mapping to output 1-2? | Rockman413 | Pro Tools 10 | 5 | 04-18-2012 06:13 AM |
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
EXPORT MIDI from Stryke NOTE FOR NOTE... |
riggi | Virtual Instruments | 1 | 03-10-2008 07:32 PM |
off topic - MIDI note mapping questions | davidp158 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-21-2003 08:29 AM |
