Mac Pro 5,1: I need USB 3 but no PCIe slots left
Any of you cats have an idea how I can get USB 3 into my old Mac Pro 5,1?
Bearing in mind I have used all the PCIe slots. Something like this: https://www.amazon.co.uk/StarTech-co.../dp/B000UZL1GC Although I was hoping for a cheaper option.
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
Re: Mac Pro 5,1: I need USB 3 but no PCIe slots left
Hi, Yeah an expansion chassis is your only route. i don't know about that chassis but i use a Magma 6 slot chassis for PT and have 2 PCIe slots left in the computer (Which i use for UAD cards) all works great. Chris
Hi James, Yes thats the one (Well actaully i have the MK1 but its the same chassis with just a different connection cable) been pretty much an industry standard for pro tools over the years. Good price that, i paid nearly £2k but that was about 10+ years ago. Chris
Bear in mind MP5,1 only has PCIe 2.0 so USB3 would require two lanes. If you have expansion chassis on x4 slot you have used half of your bandwidth for USB3 only. I would think twice if it is worth it or just replace some other card with USB3 if that is the thing for you right now. Or move somethine else to expansion chassis, which might either be great or cumbersome.
I use two Netstor expansion chassis. Each one was about 700-800 USD. Very affordable expansion.
One of them has 4 slots of SSD built in, so in addition to hosting your USB card, you can add zippy storage.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
Can add and can perform are two different things.
One PCIe 2.0 lane is 500MB/sec and you just cannot beat it. USB3 cannot fit in it so it needs two lanes. Also if you have SSD in there, you only have two lanes (1000MB/sec) left for them so you cannot have more throughput even if USB3 is doing nothing. Assuming the chassis is connecting to x4 slot Sorry for being a nerd here.
True, but my understanding is that each slot in the expansion chassis isn’t given a fixed shared amount of bandwidth. It should be variable depending on what is needed at any given moment with the 4x slot it’s attached to being the maximum.
Haven't read specs of your chassis so I'll just ignore that, no idea how the "variable bandwidth" would work in that piece of gear.
Just saying -- even with variable bandwidth, or "dynamic lanes" or whatever -- if the host card is x4 then you can have x1 from USB3 card (500MB/sec) and x3 from SSD card (1500MB/sec) if you transfer from one to another. Or full power from USB3 (x2) and another x2 from SSD card, which means 1000MB/sec max transfer rate. The data goes to host computer and back, not from chassis slot to chassis slot. And while doing such transfer any other slots you may have in the chassis have zero bandwidth. This is an imaginary situation though, because I don't have the specs.
^^ even if you allocated fixed x1 for USB and fixed x1 for SSD you would be using x2 lanes when you copy from USB to SSD. This would probably be close to ideal if your chassis has more than two slots as it would leave x2 for other use. Again, assuming your host card is connected to x4 slot.
Routing? Car panned from right to left. Now a slap delay parallel from left to right? | Sir Hannes | macOS | 2 | 06-10-2018 11:31 AM |
Question about PCIe slots | albee1952 | Pro Tools HDX & HD Native Systems (Win) | 7 | 07-04-2014 08:28 AM |
MAGMA ExpressBox 4 (2U) EB4 4 Slot PCIe to PCIe EXPANSION CHASSIS PRO TOOLS HDX | treason | Buy & Sell | 5 | 05-21-2014 03:52 PM |
Digi Expansion chassis-PCIe 'slots' | lumpo | Pro Tools TDM Systems (Mac) | 0 | 05-11-2007 03:48 PM |
New PCIe 2 slots | Toolsuser72 | Pro Tools TDM Systems (Mac) | 13 | 01-13-2007 12:35 PM |
