No sound coming from my monitors on a Digi 002
Hello! I just got the Digi002 Rack and I have hooked up my two Event Monitors to the Mon. Output L and R. I get a signal showing on the ProTools 6.4 track from my keyboard when I use Audio Track, Aux Input, and even Midi Track. However, no sound is coming out of my monitors. I have switched between Auto Input Monitor and Input Only Monitor and it doesn't matter. There's still no sound. All of my volume levels are up and the Rack is not on mute. My sample rate is currently at 44.1. I need help!
Thanks in advance! |
Re: No sound coming from my monitors on a Digi 002
Have you tried headphones?
Quad 2.5 G5, 4.5G RAM |
Create a Master Fader for Output 1&2 and see if you have any metering. Make sure the MUTE button or ALT SRC TO MON on the 002 isn't enabled.
Rail
Unfortunately, the headphones don't work, either.
Tried both and there is no sound. There is nothing on mute. I hit record on the audio track as well and there is metering, but still no sound. Any other suggestions?
bump
OK. I can tell this is going to be a long road for me. I was using the output as S/PDIF 1-2, which was what I was used to doing on my Digi001. I switched it to Analog 1-2 and it worked. Thanks to all who replied!
no sound coming out through monitors | BtotheZ26 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-23-2012 07:22 PM |
Pro Tools 9.0 no sound coming out of my monitors | shamanrock | Windows | 2 | 08-05-2011 09:18 PM |
Mbox 2 Mini Sound coming through both Monitors and headphones | jt1432 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-12-2011 11:06 PM |
No sound coming from monitors | shortyboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-11-2007 06:12 PM |
static sound coming from monitors | madoneman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-26-2006 03:37 PM |
