Old 05-01-2018, 09:47 AM
mtung mtung is offline
Default MADI: I need 64 tracks at 96k, what's best?
I'lll be on the receiving end of two fibre streams for a total of 64 tracks at 96k. Would the AVID MADI interface be able to accommodate that directly into Protools if I connect both digi ports on the MADI interface to both ports on a single HDX card?
thanks in advance!
mike
Old 05-01-2018, 10:59 AM
BScout BScout is offline
Default Re: MADI: I need 64 tracks at 96k, what's best?
Yes. In normal mode, 96k, port 1 is 1-32 and port 2 is 33-64. 2 miniDigilink cables to one HDX card will then give you 64 channels inside Pro Tools.
Old 05-01-2018, 11:36 AM
Thanks BScout!
Old 05-01-2018, 11:45 AM
FYI: If you go higher than 96k, you'll run into 1/2 channel counts. But at 96k, it'll do the full 64.
Old 05-01-2018, 02:28 PM
Thanks BScout! Just the info I needed.
FS: HD I/O, MADI, SSL Alpha Link MADI SX, 7.1 TASCAM Monitor Controller, Lucid 88192. antonis Buy & Sell 6 11-15-2017 05:51 AM
HD MADI Supports Frame Pattern MADI ??? misterGOLD Pro Tools HDX & HD Native Systems (Mac) 2 02-10-2014 11:43 PM
HDX MADI - All tracks distorted and noisy ianriggle Pro Tools HDX & HD Native Systems (Mac) 5 02-26-2013 06:55 PM
AVID MADI - connect 2 MADI units? smc917 Pro Tools TDM Systems (Mac) 4 07-25-2011 02:38 PM
HD PCIe with SSL Delta link MADI HD Alpha link MADI AX Juraj Bernáth Pro Tools TDM Systems (Mac) 3 09-10-2009 07:13 AM
