Old 08-27-2020, 11:26 AM
clausiii's Avatar
clausiii clausiii is offline
Default Can S1 follow Plugin/Send/Pan/... selection on Avid Control?
Hi!
Is it possible that S1 follows what i select in Track View on the Control app?
Say i choose a plugin on Insert C in Control and S1 goes into insert view and maps the plugin parameters of this plugin on the encoders?
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 08-27-2020, 01:52 PM
Lynn Gräber Lynn Gräber is offline
Default Re: Can S1 follow Plugin/Send/Pan/... selection on Avid Control?
Kind of. On the General tab in Eucon preferences, change "Open Windows Workstation When Knobs Assigned From DAW click" from Avid Control to Channel Mode Knobs.
That is probably as close as you can get.
Old 08-27-2020, 01:57 PM
clausiii's Avatar
Thanks, will try that!
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 08-27-2020, 11:58 PM
clausiii's Avatar
thank you. One step forward.
It seems that I´d like to have both "Channel Mode Knobs" and "Avid Control" enabled.
And I want to have that the parameters in Control follow the parameters on the S1 and vice versa.
Can't figure out how this could work...
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 08-28-2020, 06:11 AM
There is not currently a way to lock and AC with S1 like you can with the Dock.
Its not perfect, but if you are selecting your tracks from AC or the S1, the knobs and AC should both attention the same track.
Do you have "Attention on Select Button Press" checked?
You will have to manually manage what part of the channel you are viewing on each AC and S1. This is kind of an advantage though. You can view EQ on one, DYN on the other if you want. Or sent them both the same.
Old 08-28-2020, 06:32 AM
clausiii's Avatar
ok, thanks.
beside that I´m loving the S1 so far. Maybe it's time to get a Dock too
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 08-28-2020, 06:42 AM
ok, thanks.
I will say, you wont be disappointed. :)
I originally started with two S1's. I was about to purchase a 3rd, but a friend recommended checking out the Dock. It has become indispensable for me.
Old 08-28-2020, 06:44 AM
clausiii's Avatar
Oh my, i was afraid of hearing this, haha!!
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 10-05-2020, 01:04 PM
clausiii's Avatar
Got it. So great!
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Plugin Window follow DAW Track Selection Cheesehead Avid S1, S3, Dock and Control App 8 10-24-2021 11:45 AM
Setting to make plugin selection in DAW follow channel selection? polyh3dron Avid S4/S6 16 08-23-2021 09:23 PM
Edit/ Mix Window Follow Avid Control Track Selection antonis Avid S1, S3, Dock and Control App 1 04-02-2020 11:05 AM
Pan and plugin windows follow selection GuidoHelbling Post - Surround - Video 13 09-25-2014 01:38 PM
mix window does not follow c24 send selection Serge Perron ICON & C|24 0 10-19-2010 06:37 PM
