Audio imported with video is 1 frame early
Hi, I'm having this little issue with video from 1 particular production house I work with. I don't think it is a Pro Tools issue, rather something on their end but thought I'd ask if anyone else has come across it?
If I import a video with the audio, the audio is 1 frame earlier than in the accompanying omf. If I import just the audio from the video, Pro Tools converts it and it appears in sync with the omf on the timeline. They are making their video with AAC audio so I thought that might be the cause, but this morning worked on something from a different client which also had AAC audio on the video and everything was in sync where it should be. They both edit on Premiere, but the client I'm having the problem with also goes to after effects for some other stuff and exports everything from there. I'm on PTHD 12.8.1 windows 10. Anyone else come across this issue? It seems to be caused by something on their end but what..? I can work around it but would like to find the cause.. THanks |
Avid Video Engine adds one frame to imported *.mp4-files duration | Swedish | Pro Tools 12 | 8 | 11-07-2022 07:47 AM |
video on second screen lags on frame by frame moves | gonzalo.garcia | macOS | 4 | 11-14-2012 09:13 AM |
Help! Extracted Audio from imported Video DV-File is longer than the Videofile | chilln | macOS | 1 | 05-31-2011 08:13 AM |
Imported Video doesn't contain audio | DavidDubber | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-13-2010 10:54 AM |
Imported video audio loops a small fragment | tj_davies | Post - Surround - Video | 3 | 09-04-2007 11:37 PM |
