Old 05-07-2017, 10:30 PM
L-DAWG L-DAWG is offline
Default Midi not working_Pro Tools 12.7.1
Hello Folks,
So I write to you today to see if someone can guide me through getting MIDI working again in PT 12.7.1 on my PC. I'm using a Korg Triton Extreme to transmit MIDI to my Focusrite Interface using standard MIDI cables. I've tried USB as well and still can't get signal to the DAW. However, when I run a standalone virtual instrument such as Waves Element App or Electric 88 App, the signal/midi works fine. I can hit the keys on the keyboard and everything is a - GO! But in Pro Tools, when I instantiate any virtual instrument and hit the keys, I get nothing.
I've gone through preferences and made all the adjustments needed on the MIDI tab; I've gone through MIDI Studio, and finally I've made the appropriate selections under MIDI Input Devices. Please Help and thanks in advance. I look forward to your guidance and assistance.
Old 05-07-2017, 11:23 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Midi not working_Pro Tools 12.7.1
Hi, Have you selected the proper MIDI In/Out channels under the Instrument options in the Mix Window? If they aren't showing, go to View-Mix Window Views-Instruments.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-08-2017, 12:11 AM
nigelpry's Avatar
nigelpry nigelpry is offline
And record enable the track unless you have 'First Selected MIDI Track' selected as the 'Default MIDI Thru Instrument' in MIDI Preferences.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 05-09-2017, 12:40 AM
To Nigel and CW, I have they appropriate settings instantiated under the Mix Window, the Instrument Track itself and in Preferences. The track is RECORD ENABLED as well. I will do a video of the issue a little later today so you might see what I'm experiencing from a live perspective. I'll catch up with you all later on!! Thanks for replying!
L
Old 05-09-2017, 09:43 AM
25ghosts 25ghosts is offline
You specifically have to enable ANY midi device you want to use inside of Midi Setup. Please consult manual to see how that is done...
Midi drivers are fine sine the SA is working
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
[Problem] Midi Pro Tools 10.3.5 & Motu Midi Express 128 Advanced-Productions MIDI 0 05-20-2013 09:43 AM
Pro Tools Slaved by Midi Time Code or Midi Beat Clock DarylBham MIDI 5 06-14-2009 01:55 PM
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
Calling all that write/program midi drums by hand in the Pro Tools midi editor. Mikey Ace Virtual Instruments 2 10-05-2008 07:14 PM
I got a pro tools midi question( yea i know this aint the midi section) Jerry K. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2003 12:40 AM
