Re: Shuffle mode
Oh yyyyyyeeeeesssssss!!!!!!!!!!! I vote for this too.
It's a must. mike |
Re: Shuffle mode
Shuffle mode really needs to be reworked.
There are other workflows besides editing music and post. When working on long form monologues for radio broadcast and audio books you need to work from both directions. Put me down for Shuffle in both directions (selectable option+) and single key edit in Shuffle. Edit mode lock option is fine. |
Re: petition for a lock-out mode for TCE trimmer tool
I don't know if this works or not, but have you tried taking the TCE plug-in out of the plug-ins folder?
If it isn't in there, then the trimmer tool doesn't have any means to do the TCE... Just a thought... I hate that damn thing... although I did use it twice last week when I was doing some gnarly very rough editing work... time compression expansion is pretty lame in general with the digi algorithm... Serato and Waves aren't much better... Apparently more elastic audio (ala ableton live / sony acid) are on the way in future pro tools revisions... hopefully they'll find a way to implement it that won't involve the trimmer which is used way too frequently to get it all bundled up with the special purpose time compression junk... |
I wouldn't want to do that, as I do often need to use the tce trimmer. It is invaluable for editing ADR and for many things. I disagree that the digi algorithm is lame. In my experience, the different time compression and pitch tools all have their strengths. The digi one is quite good for dialog, when used sparingly. Serato is awesome for FX and some musical bits, and the graphing mode, where you can affect something over time is invaluable. I use waves, digi and serato regularly. The one that I have yet to find a use for is Speed, by wave mechanics. Every time I have attempted to alter audio with this plug I have cursed it and hit undo immediately. |
YES YES YES!!!! |
#16
i guess i wouldn't mind if it was an option to lock out.
I believe the ancient studio adage applies here in the meantime "Measure twice, cut once"
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
#17
I concur, the loop trimmer should be designed to be locked-out...or at least require a qualifier key to implement...IT'S A ROYAL PAIN IN THE BUTT !!!!
#18
but you see ... this thread is 3.5 years old and still nothing has happened
it´s absolutely ridiculous, that in a recording session the main recording DAW is the slowest one compared to all other DAW´s, far far slower
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
#19
I know it would be nice for PT to do this, but locking out the TCE tool is very easily achieved using Quickeys.
I just programmed F6 (stealing it from PT) to first choose the zoom tool (Command-1) then choose the trim tool (Command-2) and wait for .3 seconds. This way every time I press F6 (standard PT shortcut for the trim tool) I only get the standard trim tool. To choose another trim mode you would have to click on the tool itself and choose normally. A similar lock can be implemented for shuffle too. You can force slip mode if the shortcut for shuffle is used. A pain but it works. Osman
Songphonic Pro Tools Tutorials |
#20
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
How to UNLOCK trimmer tool | PTcomposer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-01-2022 04:30 AM |
Trimmer Tool TCE toggle... | danander11 | Pro Tools 9 | 0 | 09-20-2011 08:06 AM |
Trimmer tool question! | critza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 01-17-2010 04:56 PM |
Trimmer tool question | scottwilson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-29-2008 08:56 PM |
Trimmer tool (is this a bug?) | sburgess | Pro Tools TDM Systems (Mac) | 4 | 11-23-2001 01:10 PM |
